anyone try to read 2J74Y audi a3 dash failed for me
Not in circuit. Iff you read-it on a adapter it will work.
Happened the same to me.
Smok will read-it in circuit...
Everithuing that I say it is tested.
insomnia2009 (23rd November, 2016)
this programer can read write EZS,cas2, cas3, cas3+ , read other motorolas safe without any problems or damages ? or bether buy other one programer for this job ?
thanks four reply
Everythiinng (24th February, 2017)
VVDI PROG latest software version V4.5.2 update
v4.5.2 (2016-11-25)
* This version DON't need update firmware
* Fix some bugs
+ Add VVDI PROG USER MUNUAL 4.5.1 version in Doc folder
+ Add AB28F200B5T(PSOP44),AB28F200B5B(PSOP44),AB28F400B5 T(PSOP44),AB28F400B5B(PSOP44),
AB28F800B5T(PSOP44),AB28F800B5B(PSOP44)options in <1-EEPROM&FLASH>-><INTEL>(Need the TB28FXXX adapter)
+ Add HC908GR4,HC908GR8,HC908LJ12,HC908LJ24, HC908GR4_SECURED, HC908GR8_SECURED, HC908LJ12_SECURED,
HC908LJ24_SECURED options in <2-MCU>-><MOTOROLA-MC69HC(9)08>
+ Add MC9S08JM8_UNSECURED,MC9S08JM16_UNSECURED, MC9S08JM32_UNSECURED, MC9S08JM60_UNSECURED options in <2-MCU>-><MOTOROLA-MC9S08>
+ Add [V850ES/FE3]series: 70F3623 option
[V850ES/FF3]series: 70F3626 option
[V850ES/FG3]series: 70F3627,D70F3629,D70F3630 options
[V850ES/FJ3]series: 70F3631,D70F3632,D70F3633, D70F3634, D70F3635 options
[V850ES/FK3]series: D70F3636,D70F3637,D70F3638 optionsin <2-MCU>-><RENESAS-V850>
+ Add BCM3 option in <4-IMMOBILIZER>-><GM>
+ Add XIAOKANG(2015) option in <5-DASHBORAD>-><DONGFENG>
+ Add SAICMAXUS-RV(2015) option in <5-DASHBORAD>-><SAICMOTOR>
+ Add <7-ARIBAG> option in TYPE
+ Add GL8-SRS(2015) option in <7-ARIBAG>-><BUICK>
+ Add MAKKA-SRS(2015) option in <7-ARIBAG>-><OPEL>
+ Add VW52-SRS-V2 option in <7-ARIBAG>-><VOLKSWAGEN>
Notes:keep using latest software version,not work well/find bugs/good advise post here/PM me.
ahl (30th November, 2016), AndyCZ (25th November, 2016), CaioW (25th November, 2016), daxxer (25th November, 2016), Fallen (25th November, 2016), HeXeN (25th November, 2016), keyantic (25th November, 2016), Maartinj (25th November, 2016), nemena (28th November, 2016), remhonda (25th November, 2016), rob h (25th November, 2016), securipro38 (25th November, 2016), solitaire (25th November, 2016), ttzag (25th November, 2016), weza247 (28th November, 2016)
I tried erasing a few m35080, D80D0WQ without success. "could not break protection". I noticed that the preset VDD differs from the voltage measured on the chip socket during erase process. While the set value was 4,5V ,the measured was about 3,8V . I increased the voltage (VDD) in VVDI PROG, but when I set it to 5V, there is no communication with the chip. So the best I can set is 4,9V, while the real life voltage at the chip is about 4,3V. Sometimes I get "success" message, but the chip does not get erased.
strange!!
mine is work with D80
i uploaded a video for you watch it
https://www.youtube.com/watch?v=G_rF...ature=youtu.be
Actions speak louder than words
Thank you!
I can see your VCC is set to 4.4V, could you please measure the voltage at the chip pins? (1.GND, 8.VCC)
Out of work now tomorrow i will
@samic can you tell when hc05 and tms370 will be covered ?
mikajna (30th November, 2016)
why ? its old MCU, you can use any programmer, better add new mcu or another unit from automotive.
micromax
Do you trust a programmer, that cannot erase a m35080, and cannot read a lousy hc05, to do a cas4 ?
The problem with vvdi, is that it is not ok for the basics... The shitty things that almost any clone can do.
Just not VVDI.
