The question is wrong .
The real one is : Is there anything safe for cas 4 an cas 4 + ?
I have a good friend that made about 4 5m48h, and he sayd that it is ok.
But otherwise, I have not tried.
I think you will find that there's no tool 100% safe to read the mcu your talking about , the best way of putting it would be whats the programmer that is the most successful at reading correct !!
Thanks Kev
So . What did I spell wrong ?
There is no safe way. And that is it.
That includes the programmer that we are talking about.
OK, i will ask differently...
Does anybody have had any problems with CAS4 mask: 5M48H and 1N35H reading and writing with VVDI Prog???
Yes, I had. When you crack mcu I recomend use hot air. I wrote about it.
Sent from iOS
sniegavirs (7th December, 2017)
sniegavirs (8th December, 2017)
i have this adapter i tested it on 350806 , it doesnt work 4.6.5
I've read CAS 2, CAS 3 and CAS 4 with VVDI Prog.
All work good both EEPROM and Flash
I tried BMW CAS4 5M48H - can not read!
I tried Audi MED17.1 ECU tricore - can not read! (Can not crack MCU password)
I tried to reset PCF7945 - can not reset (leaves three areas that can not rewrite)
Only thing that worked is HC08 for mercedes EZS (50/50 one time read OK, other erased flash)
Having original xprogM and Orange5 I dont use this one much, but everytime I try to use for a quick solution it fails...
2 cas4 5M48 read backup is OK
I also read 2 cas 4 one for testing and the other to make key and both success from first time
habbyb (9th December, 2017), sniegavirs (8th December, 2017)
Dash mini cooper, 9s12dg128 sec, no work, no success very bad tool, r260 working fast very well
Has anyone been successful in unlocking pcf7952 of a Nissan smart key? Have tried both chip and in circuit but it is still remains locked.
Sent from my A718 Xplora Plus using Tapatalk
Griunvaldas (11th December, 2017)
