Hello, who could renew/virginize a 2013+ RAM GQ4-54T PCF7953 FOBIK / SMART KEY using VVDIPROG ?
Thanks helping as each time FOBIK stay locked using files from VVDISHOP.COM.
Regards.
;o)
Tried to clone bcm from ford mustang 2014. MCU is MPC5607B. Reading is ok but when try to write dflash it says success but after that I cannot access dflash anymore, if try to read I get reading 0% and device error, vvdi prog is stuck and must to remove usb. If I write back original dflash and try to read, it reads normal until 25% and stuck. Can anyone manage to write mpc5607b?
rob h (19th April, 2018), tehnosoftex (20th April, 2018)
After this operation , BCM is bricked. I cannot communicate anymore with it. VVDI prog is not good for this mcu mpc5607b maskset 1M03Y and cannot repair even if I try to write the backup dump. This is first time when I use vvdi prog. I am disappointed.
i try to read mpc5607 from audi gateway and for me not working, read all FF from d-flash or c-flash
tehnosoftex (23rd April, 2018)
Hi i try read ST10F276 on board RNS510 connecting as martech but not luck read chip not found . what does the (Optional - must be Lo or Hi) wiring diagram mean thanks
vvdi prog so far for me hit and miss. it is second programmer with bugs after codiprog I have. xprog and upa works better.
Hi mate, Did you actually bring details of all these 'fails' you've experienced? This way we can highlight the bbs and try push support to do something about it...
If the issues aren't highlighted then is never going to be fixed. I recently had an issue, brought the details here, and maybe within 48 hours i was given a beta version to test (although we're still awaiting the official release including this bug fix).
Seems that some just like to whinge that the tools are crap etc, and yet don't actually bring details of faults or do anything to try get it fixed. They just simply accept 'oh well that bit does't work', and thats it.
habbyb (30th April, 2018)
tehnosoftex (28th April, 2018)
Yhoni (4th October, 2023)
