I made lots of CAS3 and CAS3 + with Vvdi prog and never in any case had problems ...
Solutions in the area of automotive coded keys, all automakers.
Hi VVDI PROG has function (calculator) to change KM in CAS, or just read and write MCU?
Hi mates,
I´m thiking to buy this programmer. Can anyone share manual to check all the memory it can read? I tried to find by internet but I didnt find pdf with all the info.
Thanks in advance
ttzag...............
just read and write ?? and how do I change 125777 to 88345 ????
Hello ,
Please how to virgin PCF7961 With VVDI PROG I Don't Have the File for virgin or Only make Reset Protect ?
Hi. I've got problem with reading 93s66. When I use EEprom adapter reading is all FF. When trying with EEprom clip adapter then all is 00. With clip i don't use probe. I don't know how to use it. It's from E46 and E39 dashboard. 93c46 from E36 was ok with clip.
Is it necessary to choose right producer of the chip or only type of memory?
mickye_dj (22nd September, 2018)
Yep! Do you see the little white dot on the PCB?
And do you see the little dent on the EEPROM?
Ok, now put the EEPROM so that both marks are together.
Two more notes - yes, make sure you have chosen the correct EEPROM manufacturer from the VVDI menu. It may not be important for other programmers like UPA but for this one it matters!
And make sure you have removed the correct EEPROM from the IMMO!
lukasz61 (21st September, 2018)
It's from instrument cluster, not IMMO. Can you help with choose right memory? It's 81AB B58 608. So it's 93s66 or 93c66? What manufacturer?
B58608 EEPROM 93C66. Turn the eeprom 180 degrees.
I will try later. Will report.
Thanks!
