Originally posted by TIBIBOND
they will work as normal remote keys, because if you want to renew comfort acces keys you need dumps for CA keys...
BRMTDI response
They work as comfort access keys, every key I renewed which I did about 8, tested last night pairing to car....did 2 all worked....I am sure other 6 work perfect also....very impressed bravo xhorse
Levanime (21st July, 2017), sniegavirs (21st July, 2017)
VVDI PROG latest software version V4.6.0 update
v4.6.0 (2017-07-26)
* This version DON't need update firmware
* Fix some bugs
+ Add VVDI PROG USER MUNUAL 4.6.0 version in Doc folder
* Change some RENESAS-V850 chips DFLASH size to 64KB
* Fix GM-BCM3 option
* Fix V850E2 series diagrams
* Change KESSY(2008--) diagram
+ Add V850E-SK3H,V850-SJ3H series diagrams
+ Add NM93CS06, NM93CS46, NM93CS56, NM93CS66, FM93CS06, FM93CS46,FM93CS56,
FM93CS66 options in <1-EEPROM&FLASH>-><FAIRCHILD>
+ Add M93S06, M93S46, M93S56, M93S66, ST93CS46, ST93CS47, ST93CS56, ST93CS57,
ST93CS66, ST93CS67 options in <1-EEPROM&FLASH>-><ST>
+ Add D80(ADAPTER), D160(ADAPTER), M350803(ADAPTER), M350806(ADAPTER), M35080V6(ADAPTER),
M35080VP(ADAPTER) options in <1-EEPROM&FLASH>-><ST>(Need M35080/D80 ADAPTER)
+ Add MC9S12HN64_UNSECURED, MC9S12HZ64_UNSECURED, MC9S12HN64_SECURED,
MC9S12HZ64_SECURED options in <2-MCU>-><MOTOROLA-MC9S12>
+ Add ST72321(R/AR)6, ST72F321(R/AR)6, ST72321(R/AR/J)7, ST72F321(R/AR/J)7, ST72321(R/AR/J)9,
ST72F321(R/AR/J)9, ST72521B(R/AR)6, ST72F521(R/AR)6, ST72521B(M/R/AR)9, ST72F521(M/R/AR)9 options
in <2-MCU>-><ST-ST7>
+ Add SPC5606S option in <2-MCU>-><ST-SPC560XXXX>
+ Add ME7.5.20(ST10F275) option in <3-ECU>-><VOLKSWAGEN>
+ Add KESSY(2008--) option in <4-IMMOBILIZER>-><AUDI>
+ Add KEYLESS-ENTRY-MODULE(2009--)option in <4-IMMOBILIZER>-><GM>
+ Add HAVAL-H9-BCM(D70F3632) option in <4-IMMOBILIZER>-><GREATWALL>
+ Add BCM(2009--) option in <4-IMMOBILIZER>-><LANDROVER>
+ Add XINBAO(MC9S08LG16) option in <5-DASHBORAD>-><CHANGAN>
+ Add CRUZE(D70F3423) option in <5-DASHBORAD>-><CHEVROLET>
+ Add DASHBORAD(2013--)(SPC5604S), DASHBORAD(2013--)(SPC5606S), FIESTA(3L16Y),
FOCUS-C-MAX(2009) options in <5-DASHBORAD>-><FORD>
+ Add BESTURN-B70-SRS(D70F3623) option in <7-ARIBAG>-><FAW>
+ Add ACCORD-SRS(SPC56AP54L3) option in <7-ARIBAG>-><HONDA>
+ Add SRS-VW20(SPC560P50L3) option in <7-ARIBAG>-><VOLKSWAGEN>
+ Add A4L-LEW-MODULE(2013) option in <8-OTHER>-><AUDI>
+ Add EVOQUE-EPB-MODULE(2013) option in <8-OTHER>-><LANDROVER>
Notes: please use latest software version, any problem post here/PM me.
CarCity (26th July, 2017), chli1976 (26th July, 2017), damih (26th July, 2017), daxxer (26th July, 2017), derdud (1st August, 2017), electromech (26th July, 2017), fytfh (27th July, 2017), habbyb (26th July, 2017), keyantic (26th July, 2017), rola1971 (26th July, 2017), sniegavirs (26th July, 2017), solitaire (26th July, 2017), sv2hqx (27th July, 2017), ttzag (27th July, 2017), weza247 (26th July, 2017), yui (27th July, 2017)
Does the users of VVDI PROG have to get VVDI KEY TOOL to have access to all the renew key dumps as we only really have BMW I find it pointless seeing we have invested and its one company that we should buy another tool just for access to PCF dumps.
Fcuk up now............... ask questions later
buy from the dealer
sorry,forgot to say:it is still under producing.soon
labusas (26th July, 2017)
yes,the existing adapter can read before,but can't erase,now the new M35080/D80 adapter can not just read but also can erase,so it's more useful for you
So if it's available can you post here??
OK i have a unit here i bought to play with , there are many options on reading this unit
little confused so please advise
also will VVDI2 process to make a working chip to start vehicle ? as doesnt support unit unless is PIC typeIMG_3292.JPG
But not to erase . Allot off bla bla.
Pic 16f252 would be appreciated for next update
