Page 131 of 290 FirstFirst ... 3181121126127128129130131132133134135136141181231 ... LastLast
Results 1,951 to 1,965 of 4348
Thread: VVDI PROG
  1. #1951
    Dec 2009
    Anyone has success with M35080/D80 adapter? M35080 6 Chips are not even recognized ("chip not connect"), while without the adapter readig works fine. Tried with different vcc settings.
    Is there a hardware patch for this?
    So buying this aapter didn't take me any further..
  2. #1952
    Nov 2014
    i also have same problem cannot read cas3+ 0l15y i use r270 to read succesful.
  3. The Following User Says Thank You to philipcoin For This Useful Post:
    igorr (20th January, 2018)
  4. #1953
    Dec 2009
    Also, on the pcb there is a high freqency transmitter ic, with built in mcu. Does averyone have this chip on the pcb?
    http://www.hoperf.com/upload/rf/RFM60_en.pdf
  5. #1954
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by nemena View Post
    Clean legs and try again. Unfortunetly vvdi doesn't have leg connection recognition that would help a lot...
  6. #1955
    Poland
    Quote Originally Posted by daxxer View Post
    in what case you need use external power for VVDI Prog ??
    motorola 9s12xeq384 unsecured not work without external power
  7. The Following 2 Users Say Thank You to gif_kuba For This Useful Post:
    sniegavirs (20th January, 2018), ZanBre (5th February, 2018)
  8. #1956
    Dec 2009
    Quote Originally Posted by sniegavirs View Post
    All pins connect perfectly.
  9. #1957
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by gif_kuba View Post
    for me this MCU work without external power...i almost anytime don't use externap power...
    3M25J are in DSM benz units, unsecured and many times i read it without external power...
    many thanks to friend kevfield
  10. #1958
    sniegavirs's Avatar
    Mar 2017
    Latvia
    External power i guess is needed for some pcb's because of other component power consumption...
  11. The Following User Says Thank You to sniegavirs For This Useful Post:
    lalaina74 (21st January, 2018)
  12. #1959
    igorr's Avatar
    Aug 2010
    all mainly only about bad connecting, bad soldering or not cleaned legs - when use socket....etc...
    but solderig was ok
    for 3508 also soldering not in socket
  13. #1960
    ttzag's Avatar
    Jun 2010
    digital-kaos
    Quote Originally Posted by philipcoin View Post
    strange!!
    my vvdi prog read and write eep and flash for all kind of cas 2 and 3 .
    samic please when you add cas E65 ?
    Actions speak louder than words
  14. #1961
    Poland
    i tested on Land Rover RFA module - not communicate with mcu without external power
  15. #1962
    Poland
    Samic, its possible to add Renesas R5F64524 R32C mcu ?
  16. #1963
    Dec 2009
    Now silly thing. 24c02 b58328 from old vag ecu. Vvdi reads OK but cannot write Done with xprog and to confirm with carprog It is little scarry, device which reads cas4 (done few, all success) cannot do such easy thing
  17. #1964
    Aug 2015
    Quote Originally Posted by EMCE159 View Post
    Same problem on 95320 eeprom
  18. #1965
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    MB - Sprinter
    ECU connection
    ISP1= DSO or TDO or MISO or PGD
    ISP3=RESET or TMS
    ISP6= XMEGA PDI
    ISP9=MCLR ( 13v for PIC )
    ISP10= GND
    12V = pin2 connector KA + pin4 connector KB
    GND = pin8 connector KA
    For other connection and ori file tell to me .
    Best Regards
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  19. The Following 4 Users Say Thank You to CarCity For This Useful Post:
    BradyAus (20th October, 2018), damih (24th January, 2018), daxxer (22nd January, 2018), remhonda (22nd January, 2018)
