VVDI PROG - Page 163
Page 163 of 290 FirstFirst ... 63113153158159160161162163164165166167168173213263 ... LastLast
Results 2,431 to 2,445 of 4343
Thread: VVDI PROG
  1. #2431
    Nov 2014
    Did you see that function on vvdiprog @electrones
  2. #2432
    Jun 2010
    Hi, i hope someone can help me,
    I hava a IAW4 ecu with 95320 EEPROM.
    I modified data for immo off, but keeps overwriting the eeprom. so i need to protect it.
    I found this on HM-Autos
    To activate whole memory protection by programming 'Status Register' to 8C (possibily be xC)
    some programmer supports 'Status Register' programming such as UPA (Xprog not!)
    Now i know that miniPro has the option to do it, so i did.
    Didn't work..
    Now i read the EEPROM status with VVDI Prog, and it sas '80'.
    What do i need to put in to realy protect? Can i do the 8C like in the quote? Or is '80' right?
    Yes i know, a litle bit confusing message..
  3. #2433
    Nov 2014
    hello guys,
    please need help read Jagaur RFA
    vvdi is able to read id but cannot read file
    pictures below
  4. #2434
    Jul 2013
    You have to read it as secured and follow there other wiring diagram. You have to remove two resistors.
  5. The Following 4 Users Say Thank You to jman1530 For This Useful Post:
    habbyb (24th August, 2018), mickye_dj (26th August, 2018), philipcoin (18th August, 2018), sqlkarol (25th August, 2018)
  6. #2435
    Nov 2014
    my vvdiprog was not able to read but i used a friends own and read successful
    i dont know if my vvdiprog is hardware or cable issues
  7. #2436
    rob h's Avatar
    May 2011
    This solves most issues, Virus scanner of, run as admin, get at least 2 laptops, 32 and 64 bit.
    Quote Originally Posted by philipcoin View Post
  8. #2437
    Nov 2014
    Ok mate thanks
  9. #2438
    nickolasd's Avatar
    Nov 2015
    BMW EWS3D connection with VVDIprog. 3D is different from regular EWS3
    Ews3D can be found in bmw Z3 and some older Land Rovers.
  10. The Following 12 Users Say Thank You to nickolasd For This Useful Post:
    autocar88 (26th August, 2018), datapage (25th August, 2018), Diablotic (24th August, 2018), habbyb (24th August, 2018), jodge (23rd August, 2018), Levanime (24th August, 2018), Locksmith Hungary (23rd August, 2018), Nymike (24th August, 2018), PocketHero (24th August, 2018), rob h (23rd August, 2018), sniegavirs (24th August, 2018), sqlkarol (23rd August, 2018)
  11. #2439
    Dec 2009
    Can I renew pcf7945 in a mini cooper key with vvdiprog?
    Does it work?
  12. #2440
    ibratex's Avatar
    Jul 2015
    angola
    hello , i was waiting and waiting for mc68hc05x32 adapter today it arrived but still cant read 0g47v from ml mercedes , it stuck on 0% than says read error any clue for this ?
    tried with xprog and upa , nothing happens also so i ordered this adapter with hope since its on list but hopless
    version i am using is 4.7.1 also tried 4.7.0 any idea mates ???
  13. #2441
    habbyb's Avatar
    Jun 2010
    Romania
    hello guys,
    pictures below
    look here very nice video https://www.youtube.com/watch?v=EnrmHjC6eHE
  14. #2442
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by ibratex View Post
    why not 4.7.2 ?
  15. #2443
    habbyb's Avatar
    Jun 2010
    Romania
    hello guys,
    pictures below
    if you've been able to read put dump eep amd d-flash here . I want to check with mart tool .
  16. #2444
    Nov 2014
    Quote Originally Posted by habbyb View Post
    OK mate will upload files for you to check with marttool
  17. #2445
    Nov 2014
    Hi guys,
    Having problems reading KVM mcu MC9S12XEG348 this message pop up when trying to read
    Partition information error,please select the partition size manually.
    Have read few solution on blog.xhorsevvdi.Com
    But no solution yet
    please help
