Results 1 to 10 of 10
    Jun 2012
    Default kess v2 external exception eefface after changed nxp
    hi all!
    I have kess v2 1.89 fw old, i try firmware upgrade usb... nxp cp3 locked.
    replacing new nxp: link
    rf6 component warm... jlink write 4.036 fw ok!
    kess v2 all version started say: external exception eefface
    sd card format and copy files ok.
    please help how to solve?
    May 2012
    italia
    I have the same problem like you, npx loked cp3.I bought the same processor tme.
    I wrote bin with 3,099 jlink ok several times 1.89 and 2.06 kess program crashes, does not start
    ERROR EXTERNAL EXCEPTION EEFFACE.sd card is good, I tried 3pc Windows7 Windows XP is the same problem
    Djdanny you solved?
    Can someone help me with some advice, what should I do?
    Dec 2012
    think he re soldered nxp
    May 2012
    italia
    We solved,
    I redesigned the processor seams and works now
    Quote Originally Posted by sumi1 View Post
    We solved,
    could you explain a bit more i got one similar case here
    heteromies
    Guest
    This is usually caused by 1 pin on the nxp chip not being correctly soldered. Check also all others pins too.
    Quote Originally Posted by heteromies View Post
    i got it working yes one pin not align well
    Aug 2014
    1. Buy a new NPX chip with 60 tokens inside. Desolder the old NPX and change it with new.It cost 14-20USD, available at uobd2.net.
    2. or you have to weld a connector on backside of interface ,and plug the J-link programmer.
    You can reset the Kess v2 to virgin. UOBD2.NET is available with J-link V8, cost about 20USD. Note: the newest KESS V2 V2.06 is packed with J-link V8 programmer, no need buy additional one.
    Details about j-link v8 solve Kess V2 master tokens limited problem:
    Step 1. Buy one LPC2478 chip to replace the original one for KESS V2 master.
    Step 2. Prepare for a LINK J-LINK V8 ARM USB-JTAG Adapter Emulator.
    Step 3: weld a connector on backside of interface.
    Step 4: plug the J-link programmer
    peko's Avatar
    hi friends
    anyboby have test to update fw to v5.xx ?
    electronistul21's Avatar
    Nov 2011
    galati,romania
    [QUOTE=sumi1;2542017]I have the same problem like you, npx loked cp3.I bought the same processor tme.
    i think you make confusion 1.89 and 2.06 ist not firmware ist version SW . firmware ist 3.099 ,4.036 and 5.017 (new).Version of firmware can read in info when connect programer to laptop and open software.
    EEface -bad soldering NXP.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
