xtrend 8000 no internet connection
Results 1 to 6 of 6
    Sep 2008
    Default xtrend 8000 no internet connection
    new box running hades 10 image and in getting it first setup was nearly impossible but connected.
    had the sparks in today putting in new sockets so power was off,and yes box refuses to connect no matter what i try.have the solo,duo,solo2 tm nano and max digital so am aware of how to reconnect,this cable box refuses a net connection,box and router off and on,new lan cable fitted and just pulled box out green and yellow at lan port,restarted network internally and run network wizard and same message =no connection to internet?did i miss something?
    duo above had same issue and reconnected in less than 5 mins
    Sep 2008
    box is going back to seller as once box is rebooted it will not reconnect to internet,box has to be off for 1/2 hour and cold to reconnect again.
    Sep 2008
    update at long last fault was found and offered a replacement
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by cactikid View Post
    Thank goodness for that did you go for another replacement ET8000 or a different model
    Sep 2008
    et 10000 quad tuner 2 cable and 2 sat tuners for extra payment,now looking for 2.5 hdd of around 3tb if possible,dont want to go overboard and get a 16tb
    May 2010
    Et 10000 Is this box good , is it worth ? n how its working thgh dish or cable, if dish which one (sy or vr) or both n do we need scrb..... ,
