test with this file
I need immo off for Renault twingo 1.2 8v Siemens sirius 32n S11013800b. I have the file from m29f200b inside ecu, but it is sodered again so I don't know if it is the right dump.m29f200b original file s11013800b.zip.
Thanks in advance
test with this file
this is a solution for common sirius 32 ecus when you change to ff 4000 to 8000 bytes. I would prefer if somenone has allready anohter file immo off for this car twingo 1.2 8v because I doubt that the data are original of m29f200b. Thanks for sending but I will try this last choice because car is far from me
Test this.
I already test it.
cicko (19th November, 2017), gixxer (4th December, 2018), jasnicdusan (12th September, 2016), liban11 (27th September, 2018), Nik Matsa (15th June, 2015), retrofized (7th January, 2018), sebdetours (13th September, 2015), sofhos (15th February, 2019), TROIA 17 (27th January, 2018), ubistvo (15th April, 2016), VORTEXANDREJ (19th February, 2017)
thanks circuit, I will test and post results tomorrow. I have to cut 58 too or desolder 333 resistor?
sebdetours (13th September, 2015), ubistvo (15th April, 2016)
YES several soluce
ahmed66 (19th January, 2022), lesakljucevi (8th March, 2017), sofhos (15th February, 2019)
worked fine circuit.fr. thanks
Please password for this file in pm.
Please passw.
Circuit.FR work fine you solution with resistor?
Thank you
hi, I also have a bypass\ off file. I can help...but how do I upload dump?
I am new here...
are we allowed to share e-mail address?
No mate,you're not.....
Pass please I have same ecu
