It sound like your using the 'Sat' epg and not the 'Xmltv' epg. To get the 'Xmltv' epg you need to have a USB drive in the box at all times and set it up via the remote: menu-sytem setup-epg and time settings.
Can someone tell me whether there is problem with the boxes software that will not allow more than 1 hours EPG listing of programs. I have heard that it is supposed to show you up to 7 days but my box only shows me 1-2 hours worth of programs.
Can someone please tell me if this is something wrong from my side and how i would change the setting for 7 days to work.
You will also need the latest firmware from skybox.cc dated 2015/05/19 if you haven't already installed it.
Hadron (30th June, 2015)
I have checked the software version and it is dated 7/12/2014 which means it is out of date. I would like to know whether the server settings will be deleted during the update and also how would i be able to save the current server settings.
When you install the new firmware, select "Keeping DBS & setting" = yes. This should keep all your current settings.
Although it should keep all your settings, make sure your "important information" is already backed up to your pc or USB stick first. To do this, you will need to "dump by USB" & select "misc files". Scroll to "select & dump" & press OK. From the list, select the appropriate files.
Your important info will be in 1 of 2 possible places. We cannot discuss this in detail on these forums due to the rules. If you don't already have this information on your pc, then you will need to dump it to your memory stick.
The chaces are that everything will still work as normal after you have installed the new firmware, but it's always best to have a backup, just in case.
