My own List (somthing wrong)
Results 1 to 3 of 3
    Junior Member 50pounds's Avatar
    Oct 2008
    Default My own List (somthing wrong)
    Okay here goes ive moved this list around for me only and im using dreambox edit 6.0.2.0 i can get bbc channels fine and all channels scan but when i go to sly sports or even ci i get Tune Failed
    now the dish is done correct
    i used cats eye this work prefect
    just mine does not seem to work anymore i dunno whats happen maybe someone could take alook?
    DreamboxSeV2 (openPli4.0) - Clone
    thank you
    Sep 2008
    check with kingofsat for movement on channels very often you get tune failed=moved tp and makes channel lists out of date needing new ones on a regular basis.
    if wondering why hd channels dont work ,only provider box can view the hd content.no hd movies,sports and loads of others.
  3. The Following User Says Thank You to cactikid For This Useful Post:
    50pounds (4th July, 2015)
    Oct 2008
    this is what i do i scan my box using a updated satellites.xml file then i open dreambox edit open my channel file then go to tools > compare loaded services with services on dreambox
    then i update this way maybe ive messed up my lamdb?
    *EDIT*
    sorted it well its gonna take awhile i have about 5 skysports news and the one i have is the wrong transponder :s ill sort this on nights haha thanks for the help
