Hello, good result, but 36PS after injectors, turbo, ic little low.
How much boost now ?
Something change on exhaust ? What is TTE turbo upgrade ? Billet compressor, hybrid modification ?
dyno sheet, more infos, only hp , nm values not enough
you cannot go from a stock setup and think your HP & Torque will be the same if that was like that hahaha then it was 500hp hahaha
the TTE turbo is a Hybrid
exhaust is cat removed
so the results are verry good, so remember we did not tune the DSG its stil stock sw
he guys, where can a find a upgraded turbo for the mk7 R20 mine is dead after onley 49000km :/ i was thinking first for a original replacement, but don't want to change it again whitin 49000km
i drove 140kkm with stock turbo! Change your driving style, or use better oil!
DSG TUNING
File Service
