Highly doubt it will disable the car from starting..Do a full system scan.
Does anyone know how to enable it back?
EIS is disbled, so no crank or starter. Everything else act like normal. M.E gets power and show on cluster.
Everything else has been checked, pyrofuse, pre-fuse box, etc.
Should I have to have all the deployed airbags repaired before it let me reset the car? Airbags are still deployed awaiting for a solution to quote customer for a total repair bill..
Only M.E shows a Circuit 15 code.
AB shows only all the deployed airbags, but nothing about COLLISION PREVENTION
Only in cluster shows the COLLISION PREVENTION DISABLED..
Any tip???
you need reset, AIRBAG MODULE, immo is detecting that code in AIRBAG MODULE,
It is possible through obd or the module need to be done manually?
hello friend
i have same case in w205 2015.. you solved ??
Make the diagnosis and all active codes and events lay out here!
Everything will be okay!
hi all, had this a few times...solution is this
do a scan with xentry, go into engine ecu...then hit adaptions and teach in process.. now to the bottom where it says "start disabled due to crash event"...something like that anyway
there is a green arrow just below, hit that and run the process. this will lift the lock ...you may get error saying it hasn't completed, ignore it as it has done it....worked everytime for me
regards simon
Air (29th October, 2016), autocentarvu (19th September, 2016), AVDIMON (25th October, 2016), AvechuchoAxel (31st August, 2016), huzefa (12th July, 2016), servicetecnocar (12th July, 2016)
Simon..... Today I have a W166 GL450 2014
I found the "start enable", but no arrows or options. Just indicates that pressing"continue" will abort the process. No process is started..
Any clue why?
Software version 9/2016
Also try before with 5/2016
Here the screen capture. .
Hello Guys..... I do still need help...
ML 350 2013 and GL450 2014 same S#!t ... cant enable starter,,,.... Please !!
I had pre safe failure on benz before I fixed them and all of them start..something is missing here...did you check the pyro fuse?
I have a similar issue on W205 C300 2015, I will perform the Teach In Process and see the result morrow, even though I have not replace the airbag module or virgin it yet
are all these vehicles hybrids?
