Page 13 of 65 FirstFirst ... 3891011121314151617182363 ... LastLast
Results 181 to 195 of 970
  1. #181
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by abaseiro View Post
    I have carprog 9.31 how I can update my library?
    thank you
    Its a clone, I doubt you will be able to update it at all.
  2. #182
    Aug 2008
    thank you
    you dont have 9.31 at all.
    look at your serial and it will be for fw4.01
    so only way to update is to flash with fw4.74 (free)
    or flash with fw8 (paid for)
  3. #183
    Jul 2015
    Quote Originally Posted by tango View Post
    he said he has version 9.31 though?
  4. The Following User Says Thank You to Catdaddyfunk For This Useful Post:
  5. #184
    Aug 2008
    Quote Originally Posted by Catdaddyfunk View Post
    did you read anything i posted?
    obviously not
    9.31 = software version only
    fw inside mcu will be fw4.01 nothing more
  6. #185
    Nov 2016
    HOw to update carprog ? anyone can pm an update
  7. #186
    nickolasd's Avatar
    Nov 2015
    same thing with me, original carprog, bought it for dashboards mostly, it pretty much never works over obd, tested with A9 adapter all good, will try to send it back for repair.
    Quote Originally Posted by nitroCZ1 View Post
    I have original and work 10% of function...shit
  8. #187
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by nickolasd View Post
    Not all the dash are usually the same type same..Obd dash I cant recall having any issue at all using CP. Just this week I tested a 2016 Mazda 3 & Dodge Durango 2016..Take for example 2015-16 ford explorer some have eeprom and some mpu. some can be done obd and some cannot. If you have issue with some cars then send them the log let them take a look at it.
  9. #188
    nickolasd's Avatar
    Nov 2015
    im not talking about dashboards tool may not support, I'm talking only about dashboards and connection they claim tool supports, recently tested on: all obd, 13 Ram read ok with communication errors, didn't try to write , 12 nissan qashqai read/write flash ok read milage ok fail to write, any volvo vehicle software crushes as soon as i try to read. i sent to customer support all logs dumps flash dumps pictures and descripton of problems, non of my problems was ever resolved. for me tool worked over obd only on some older VW's which can be done with any $50 china tool. yes it seems tool works ok with direct connection on a table, but i have UUSPS for that purpose, no need for such an expensive tool for direct connections.
    Quote Originally Posted by FxShaw View Post
  10. #189
    FxShaw's Avatar
    Nov 2013
    Outta This World
    I just so happen to do a 15 ram with cp and rogue 2013+ using cp, the rogue is a lil tricky, got to write flash first then u can change miles after. You might want to check yr A1 cable.
  11. #190
    Jan 2017
    Chesterfield s43
    081105CAR001773I.rar
    hi guys, only joined this site today but read this thread from start to now. i have recently bought a cp clone from ebay and used it once or twice with limited success for instance cleared crash on a t5 airbag module fine but an 01 cleo airbag module would read but not find crash at all so had to save dump and clear with airbag service tool then write with car prog. i also tried to pull a sec pin from a 2006 diesel zafira over obd and it gave me a pin but was incorrect, had to remove eeprom and find it maually in the dump.
    anyway my carprog was advertised as latest version 9.31 but i assume its just got crappy 4.01 fw but my clone does not have a counter so if it would be any good to someone wanting to remove counter i can upload. its marked as 081105CAR001773I.lib
    i read theres a fw that is purchasable??? what one and how much is it? i have been on codecard and see that you can legitamise a clone now but i dont use it enough to justify 1000 on going that way but i would spend a bit of it if i could get a more upto date one than 4.7x
  12. The Following User Says Thank You to sye27781 For This Useful Post:
    lumetan (13th January, 2022)
  13. #191
    Aug 2008
    the fw that you want is posted on here and a few other forums now
    fw version 8.xx
    look carefully and you will find it here in forum
  14. #192
    Feb 2017
    I have been doing a lot of reading and am almost ready to purchase Carprog. From what I am seeing it is widely used on European vehicles, does it work just as well with North American vehicles? I would mostly be working with GM, Chrysler, Honda, Toyota, and Ford. Right now I am only interested in resetting airbag modules.
  15. #193
    Minsk
    hi. please help, carprog clone will not work with programs 6.XX or more versions
  16. #194
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by Flipg View Post
    You will need more than one tools to do them but CP is a must imo.
  17. #195
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by 1dimon View Post
    What lib file are you using? what exactly isn't working?
