Tomorrow i will have MM74hc125M and 74lcx125mtc for test.
yes I know that, I have read it more time by xprog. I want to test my carprog.
where did you buy 74HC125M ?? ebay en ali does has only 74HCT125D
i find it on mouser.com but chip cost self 50 cents, shipping cost 20 euro !!
do you have more 125M ? i can pay you with paypal
i had another carprog main unit as you all know they break... all my others one's were reworked... so had the same issue couldnt read 24c and some motorlla mcu - change for HC125M not (D)
done mine last week works fine now..
got mine from fleebay uk next day delivery
If i helped.... please dont forget to press the THANKS + REP buttons .
My D1 adapter contains HC125D.. Replace too?
are these correct parts ?
1- FAIRCHILD SEMICONDUCTOR MM74HC125M... Buffer / Line Driver, 74HC125, 2 V to 6 V, SOIC-14
2-TEXAS INSTRUMENTS CD74HC125M Buffer, 74HC125, 2 V to 6 V, SOIC-14
In my case change for 74HC125M doesnt help. Still cant read or write HC08. I dont know what is wrong.
24C and 93C works OK. Does anyone schematic have?
Maybe im doing something wrong. In carprog choose 2J74Y and flash. But the address and size is same like in eeprom! It must be set manualy? And what about security?
In your case, 24c was solved by switching to 125m?
I don't think it is an internal issue with cp ...3inferno3 is right...
🔥Wacka Wacka 🔥
Yes 24C was solved by swtching to 125M. Hc08 can read only eeprom part, but flash part cant.
j0anita (27th April, 2017)
Just in finish to flashing the mcu, I broke my atmel pin :@
With an brand new atmel chip, is it the same procedure? Just put in pcb and flash the file? Thanks
please someone can confirm it ? this is a correct one ?
CD74HC125M96 IC, NON INVERTING BUFFER, SOIC-14 TEXAS INSTRUMENTS
Logic Device Type : Buffer, Non Inverting
Logic Case Style : SOIC
No. of Pins : 14 Pins
Product Range : -
Automotive Qualification Standard : -
Operating Temperature Range : -55?C to +125?C
Propagation Delay : 17 ns
Supply Voltage Range : 2V to 6V
or this one ????
MM74HC125M... IC, 74HC CMOS, SMD, 74HC125, SOIC14 FAIRCHILD SEMICONDUCTOR
Product Range : -
Logic IC Family : HC
Logic IC Function : Quadruple Buffer / Line Driver (3-State)
No. of Gates : 4
No. of Inputs : 2
Operating Temperature Range : -40?C to +85?C
Termination Type : Surface Mount Device
I used second one MM74Hc125m
