It is the firmware of this post, number of mesage 1 and 3
Enviado desde mi Redmi 3 mediante Tapatalk
Is it possible that the eeprom is deleted? I tried it with another FW and it does the same 150428CAR00491KW
Someone can try to read the ECU of airbag of a Renault: 0285001157
No need to connect the A15 only the carprog, with my carprog when reading, it tells me the error "unit version conflict"
I have tried many different firmware
Everything else works very well
BWF (29th July, 2017)
Hello guys
I have a carprog 9.31 , when I connect USB to carprog it doesn't change anything on device manager (XP) ? But it still does make the windows XP noise to confirm that a device has been connected? Can anyone please help with this problem?
Carprog says "no device connected"
Please hit thanks if this helped you!
Good morning, my carprog can not read the eeproms 24c, the others read them well. I have mounted the 74hc125m.
I have clone and real carprog. Neither have GM airbag models, there are some but I never found a match for any of the srs modules I tried to clear crash from.
Is is there a software for GM airbag modules USA market for carprog ?
carprog Opel/GM airbag reset software , the one for 09-15 years, does it work with American market GM cars or only European ?
I have 9.31 clone.
If flashing the item working the renault nec part?
Hello friends know how to release the ford ka 2015 r5f10 obd2
Version 8.21
Audi q7 original mileage 300000km tried to put 200000 and it jumped to 0
After that used vcds to put mileage to 200000 and it worked
Hello, does anyone know how to solve this problem?
Thank you
Press Thanks and Reputation
No counter left, reflash
Keep in mind, English is not my native language.
