Page 27 of 65 FirstFirst ... 17222324252627282930313237 ... LastLast
Results 391 to 405 of 970
  1. #391
    dadal's Avatar
    Aug 2015
    Quote Originally Posted by 3inferno3 View Post
    For all. Very easy way to do antena for immo carprog transponder software. from peugeot 206 or 307 immobiliser antena which she has 20 om. and we must solder 4 capacitors and one resistor on main PCB.I share few photos with my clones ...they are work on 99% with ver 8.21.
    Im going monday to scrapyard Can you give more details ( or some pics ) about that parts/value ( cap and resistors ) ?
  2. #392
    3inferno3's Avatar
    Nov 2014
    Europe
    Quote Originally Posted by fogducker View Post
    Will this 206 antenna work with genuine Carprog hardware without any modifications to its PCB?
    I swap 4 capacitors and one resistor na PCB and work like harm picteres are up side
  3. #393
    Nov 2017
    Hi.
    Yesterday appear in my CarPRog software the follow message: "236 unit left. Connect update Serverto Synchronize"
    How I can remove this message? I imagine that with 0 unit left I cant use this tool.
  4. #394
    Feb 2017
    Armherst, OH
    Recently I purchased the carprog of ebay, the one that had the most items sold, and I tried fixing the airbag for a honda civic,
    When I found the part number and tried to go ahead with the repair, it said " Required update is not active "
    Should I just take the eeprom off, find the corrected data and re-write the eeprom, or is there a way to fully unlock carprog?
    Software version I have is v09.31 and v10.05, Thanks!
  5. #395
    Dec 2017
    hello I have a carprog 9.31 clone and I would like to know why the son color I have on the picture do not match the color I have on the adapter
    thank you
  6. #396
    May 2016
    Kaunas
    Clone is a clone.
    You must check all adapters according to the correct pinout.
  7. #397
    Dec 2017
    that is to say ?
  8. #398
    May 2016
    Kaunas
    http://codecard.eu/index.php?page=1&...ewCat&catId=32
    Each adapter's description has a pin connection diagram. This requires checking all the clone adapters. There are many discrepancies with the original. The color of the wires is also incorrect.
  9. The Following User Says Thank You to vaicekas For This Useful Post:
    maarcob (2nd December, 2017)
  10. #399
    Dec 2017
    how to modify its adapters?
  11. #400
    Sep 2016
    Budapest
    Hello!
    Somebody can help me?
    I use a clone V4.01 version and on a day I have got this message:
    Device locked. Connect update Server to synchronize
    What does it mean?
    Thank you very much!
  12. #401
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Quote Originally Posted by tonyoa78 View Post
    Hello!
    What does it mean?
    Does reflash help you.
    Press Thanks and Reputation
  13. #402
    Sep 2016
    Budapest
    Thanks.
    How can I read AT91SAM7S256 mcu? What kind of tool read it?
  14. #403
    May 2016
    Kaunas
    Thanks.
    Read - no way.
    Just delete and write with J-Link
  15. #404
    Sep 2016
    Budapest
    J-Link only?
  16. #405
    May 2016
    Kaunas
    I use wiggler jtag
