Page 28 of 65 FirstFirst ... 18232425262728293031323338 ... LastLast
Results 406 to 420 of 970
  1. #406
    Dec 2017
    I have a clone version v9.31 and for airbags it can read the chip but it reams when I want to erase the crash, normal or not?
  2. #407
    Mar 2016
    Thanks FxShaw , for estract and riconpose split 00.. in .zip use this software
    Quote Originally Posted by FxShaw View Post
    Yes... I have many times & after done flashing you would have to replace HC125 to HC125M as marked in step 4..Other wise it will never actually write to anything.
    Adding Carprog Antenna Fix.. Thanks to PierreTheron for the Info.
    CarProg 8.21 included with lib, exe, firmware with no activation needed. Extract 4 zip and then open zip file and extract.
    Lets not forget that there is a Thanks & Rep button, Feel free to use it .
  3. The Following 4 Users Say Thank You to PaoloDigital For This Useful Post:
    badziewo (7th January, 2018), ecufix (16th April, 2020), ferchichi (11th March, 2018), FxShaw (12th December, 2017)
  4. #408
    Nov 2017
    How i can read thes module air bag for Renault symbol
    Can i read by carprog. And how to do?
    Sent from my VTR-L29 using Tapatalk
  5. The Following User Says Thank You to shreef For This Useful Post:
    abdullah esam (12th January, 2018)
  6. #409
    Oct 2017
    Finland
    Hey to all.
    I'm trying to read Honda 95640 in a adapter board. I have 8.21 and 7.24 units, tried many different softwares but no success.. Chanced original 125d to texas 74hc125m, 47 cap on place, 2.2 SMD's chanced to normal resistors etc. First without any mods to the board it red the eeprom fine but verification failed every time.
    With this current setup, windows 7 blinks all the time that something is connected and disconnected very rapidly. Doesn't work at all. What to do next??
    Any help would be great.
    Thanks.
  7. #410
    Nov 2017
    Quote Originally Posted by shreef View Post
    J-link read this
  8. The Following 2 Users Say Thank You to bumba For This Useful Post:
    geocity (16th January, 2018), shreef (17th December, 2017)
  9. #411
    badziewo's Avatar
    Feb 2016
    Universe
    I have upgraded my carprog 4.01 to 8.21 with FxShaw files.
    Works perfectly without replacing 74hc125.
    Thank you FxShaw.
  10. The Following User Says Thank You to badziewo For This Useful Post:
    FxShaw (5th January, 2018)
  11. #412
    Trstenik - Thun
    Default Everything Carprog...
    Quote Originally Posted by badziewo View Post
    Thank you FxShaw.
    Which firmware ?
    I mean what serial number?
  12. #413
    badziewo's Avatar
    Feb 2016
    Universe
    150428CAR00577RU
  13. #414
    Trstenik - Thun
    150428CAR00577RU
    Does renault airbag work in this ver.?
  14. #415
    badziewo's Avatar
    Feb 2016
    Universe
    Yes it does work .
    Tested on Renault Megane 3 285581365R
  15. #416
    Trstenik - Thun
    Yes it does work .
    yeah but not all listed
    some work good but some Bosch module give "unit version conflict"
  16. #417
    mapexo's Avatar
    Mar 2017
    Germany
    not work Original carprog not read obd SRS toyota renesas mcu!
  17. #418
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. I have carprog10.05 but no unlock options im mcu programming, transpoder, airbag some options are n/a some are ok. Is 8.21 better or it is the same story?
  18. #419
    May 2016
    Kaunas
    Your carprog is version 4.01. Therefore, many points will not work.
    You need to write firmware 8.21 to Your carprog, and use 8.21 software
  19. #420
    PSAcars's Avatar
    Oct 2015
    HOME
    hello, thank you, the seller told me that is 10.0.5. Do we have here i DK good working dump dor 8.21
    Sent from my Lenovo A6020a46 using Tapatalk
