badziewo (7th March, 2018)
Hello. I recently purchased a Carprog clone v10.05 off of ebay. Will this be able to perform an airbag reset on a 2015 4runner?
Anyone had any luck reading a Benz W211 285 001548 SRS module with a CR16MCxx mcu? I'm having a time of it; k-line times out, it can read and clear codes via obd but cannot clear crash data. Oh, it's a V9.31 clone.
I have problem to extract files from post 3. Please help
Use this to split files
badziewo (19th March, 2018)
Ok it is done
Mine is original but nothing like the pic of FxShaw above.
There is no board at all just wires going straight to the corresponding pins according to the diagram plus the two resistors and the diode. Here is original schematic: http://codecard.eu/carprog/adapters/a10-carprog-motorola-mpu-programming-adapter/prod_73.html
I must say though that i have this tool for about 10 years now but was never able to read and write any Motorola MPU and no Ford air tool is working either on the bench or via OBDII as it Writes but never verifies OK as many bytes are always different. It is to my big disappointment for such an expensive tool... I was asked to send it back for service but need the rest of its services so i never did. Checking it though with A9 all tests pass OK!
I gave Up and use X-Prog for most work as it is much more reliable...
Best Regards
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
CARPROG (original) and RENESAS srs unit : version 11.13 online
Hi.
I want to make a psg16 adapter. The same that the we can see in the webpage of carprog.
My question is:
Is it necesary the relay or I can make conection without the relay? I dont see the diference
Hello Friends!
I've managed to destroy my Carprog (clone) with a short circuit (accidently) on the PCB while it was running
I killed the AT91 + AT88SC.
I changed and reprogrammed the AT91, but now, how i can get a working AT88SC Crypto memory? Is there still no solution yet?
I can lend a Beeprog+ from a friend. Can it write this Chip?
I found only one Dump for the AT88SC, but i still don't know if this dump works or not.
Can somebody help me?
BR Matthias
