Newbie Q:
Carprog Clone... will it replace the Renault Clip for diag and programming?
Is there an official shop for the HW?
Toro
New eeprom adaper v2018 with full reworked Carprog
https://youtu.be/yQQU1_i4TdA
Newbie Q:
Toro
FxShaw (6th June, 2018)
Hello , I have a problem with my carprog. I have flashed the mcu a few months ago and I haven't used my carprog since then. Last week I've tried to use it and didn't worked. I have tried to reflash mcu again and I broke some pins. I bought new mcu from farnell. After the flashing process, I solder the crypto back and when I connect usb sometimes doesn't recognize the device and when the device is recognized carprog doesn't show any serial number..
Wrong processor !
ovidiumarin (4th September, 2018)
I had exactly the same. If you have no SN, your AT88 is empty / damaged.
You can reflash with old cracked 4.02 that don't need AT88. Check Attatchment
@mikroel
It's the same processor AT91SAM7S256-AU
@kostelectronics
Thank you , I will try it soon.
AT91SAM7S256D-AU , is D
Hello everyoneSomeone who uses carprog clone for the clear and can give me an opinion.It works properly or corrects files at random. I wondered why I never used it for airbags. Now playing a little 'I noticed that even if the control unit is not in crash corrects the file anyway. I can trust?
did not you understand the question? I translated badly?
Inviato dal mio iPhone utilizzando Tapatalk
Hi, All,
what is the actual truth about removing the AT88 chip during reprogramming? :-)
