Page 38 of 65 FirstFirst ... 28333435363738394041424348 ... LastLast
Results 556 to 570 of 970
  1. #556
    Oct 2018
    Oman
    Hello friends
    I’m new in carprog i have 2016 nissan altima with crash data module (98820-9HS0A) XC2336B40 .
    Fristly, how can i read cash data from airbag module which unit and program use?
    moreover i have carprog 10.93 with full units but i dont know how can use it and what is the cable need ,what is the circuit to connect with eeprom???
    anyone can help me by pic ?
  2. #557
    Sep 2016
    Quote Originally Posted by mohammed alisma View Post
    Hello friends
    The video in the link shows the connection at 1:27 - https://www.youtube.com/watch?v=wcYb_Zzk_VU
    However, This may be of some info to you http://www.digital-kaos.co.uk/forums...s-with-carprog
  3. #558
    Sep 2018
    hello, in carprog v8.21 no mini cooper, maybe is update?
  4. #559
    Jun 2018
    hello.I have successfully updated my carprog from 081105CAR001773I to online version 8.21. Now I have only one error with D1 adapter.
    Carprog alone + A9 pass the test OK.
    Carprog + A1 pass Test ok.
    Carprog + A9 in Test D1 = all ok.
    Carprog + D1 + A9 in Test D1 say errors
    UART1: ok
    K Line 100k/5v: ok
    K Line 1k/5v: ERROR
    K Line 1K/12v: ERROR
    K Line 100K/12v: ERROR
  5. #560
    Sep 2016
    Attachment 562289
    Does any one know the value of the capacitor in the green box? My capacitor reads a zero value...
  6. #561
    Jun 2018
    Dashboard Fiat 500 obs II - I get an error while reading.
    Unit CRC error: Delete LIB file ....
    Sn: 150428CAR00577RU
  7. #562
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Quote Originally Posted by theislandhub View Post
    Attachment 562289
    200uF........
    Press Thanks and Reputation
  8. The Following User Says Thank You to Kocta For This Useful Post:
    erniss14 (20th October, 2018)
  9. #563
    Sep 2018
    I've got problem with my carprog clone 8.21 online. It doesn't read eeprom - shows only 00 values and when I'm reading ECUs by OBD (A1 adapter) it shows wrong values Immo PIN. I changed all 74HCT125 and crystal quartz. Carprog passes all tests.
  10. #564
    Oct 2010
    Hello mates, I wanna ask one thing, carprog 8.21 clone have all function activated?
    Best regards
    Remember thanks and reputation buttons if helped
  11. #565
    Trstenik - Thun
    Quote Originally Posted by joze View Post
    Best regards
    Yes but some functions still doesn’t work, for example dacia dash , airbags and some of Renault airbags .
  12. #566
    Oct 2010
    Quote Originally Posted by mikroel View Post
    Ok, I’ll try it, I have version 10.05 and not have many functions activated
    Best regards
  13. #567
    Oct 2018
    Bulgaria
    Hello ! I, like everyone else, have problems with my Carprog antenna. Chinese Clone Version 8.21. I read tons of antenna repair information. I did all the known corrections so far. Htrc110 was defective. After the replacement, I tried again Chinese antenna, antenna from VAG but the results were unsatisfactory. On a sample of different antennas, I re-calculated the resonance frequency of the LC group. I found info and made my own antenna. As a result, he began to read partially VAG transponders.I test with ready and runnig keys from pasat b5 and fabia mk1 with transponder Id48. I have no trouble to reading ID and UM1 , but when reading UM2 have error weak signal from transponder . Both transponders are locked.With locked transponder should I read UM2? What is UM2 and can I add a new key without reading UM2 ? On the PCB I make the following adjustments - I cleaned a PCB ,replacing the 74HC125D with MM74HC125M, replacing the HTRC11001T, soldering the whole board and other minor corrections. The board is with firmware 150731CAR00064RA . I do not see how to apply photos. Anybody have an idea on the subject?
    Thanks !
  14. #568
    Kocta's Avatar
    Mar 2017
  15. The Following User Says Thank You to Kocta For This Useful Post:
    kebappa (31st October, 2018)
  16. #569
    Oct 2018
    Bulgaria
    I have done these procedures by calculating capacitors, resistance of the whole antenna (including the grenator), current through the antenna during reading and recording. The problem is that everything is calculated and the antenna can read the transponder to the end. I have tried with other values, but my greatest success is reading the ID and UM1 of ID48 transponder.
  17. #570
    Jul 2016
    USA
    I’m trying to clear crash data for tms320 Honda module. Carprog are not replying to my email about buying airbag activation for the legit programmer so I’m using second one that is a clone.
    I keep getting “connect d1” error.
    ( D1 was repaired with upgraded components tho. )
