exotictoys (13th November, 2016), PierreTheron (25th September, 2016)
can i get the update for 89170 B2C60 , 89170 52J30 Airbag reset (Toyota)
MY device sn is 081105CAR001773I
I have original and work 10% of function...shit
what do you mean you have an original carprog and only 10 % of it works ?
im will order tomorrow as clone has no support is real one worth it i can read eeprom my concern is GM American models ford with mcu and any with mcus eeprom i got covered
hi guys does any one knows if carprog clon chinese does infineon chip?
CARPROG Original some products rose 25% ....
I have original CarProg for many years. The board is ...CAR002... and there is no repair info about it.
My problem is that i never got it to work with MCU Motorola, any Motorola either reading or writing. From the helpdesk at Codecard they offered me to send it back for checkup and repair if needed but i never had the time to send it as i use it in a daily basis for other work.
Anybody had a similar problem and have a solution for it?
Best Regards
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Do a A9 test or just order the repair kit and replace.. http://www.codecard.lt/carprog/carpr.../prod_566.html
speedy100 (25th October, 2016)
Thank You for Your reply!
As I was informed from Codecard the repair kit is not for units with serial number ...CAR002... like mine but only for ...CAR001... and ...CAR003...
As for the A9 test i should get one as i do not have it.
So for the moment i am stuck.
Best Regards
hi
i am new to this sector.I just bought carprog 9.31 and tried to read the eprom.Can any one tell me how to copy bin file and to attach that file in the forum.when i tried to attach the bin file,the sites says not possible to attach....what software i should use to save bin file?
many thanks in advance
you need to use winrar and compress the file then upload that rar file
FxShaw (1st November, 2016)
many thanks..let me try
I have carprog 9.31 how I can update my library?
thank you
