hy,
i made aa mistake... it is about a delco ECU... sorry.
thanks.
hy,
i need help to read / adjust mileage on astra h 1.7 A17DTR denso ecu. carprog (clone) read correct km value, correct VIN but a strange value for PIN code(+AHM). when try to modify the mileage carprog makes the modify but returns verry high value(about 8.600.000 km).
also the dump's that i can read are strange, same 2 strings are repeted many times... attached the dump for "read eeprom raw", "read eeprom 2" and "read flash".
can anyone help me...
thanks in advance!
hy,
thanks.
Hi all. i have a problem with my clone. It was 4.01 i make update, all staff is unlock but i have whis error. Someone can help me please?
Thanks for sharing. What is the tantalum's capacity used for reparing A1? I couldn't see the numbers in photo.
Rework CP....
Press Thanks and Reputation
adamwajda (21st July, 2021), al70 (19th June, 2019), angmar (5th January, 2019), cinci (18th October, 2023), deteli (30th March, 2018), ecufix (16th April, 2020), eliah (2nd March, 2020), Feridhap (22nd November, 2019), florin_leo (28th February, 2021), freerefill (7th November, 2018), huwalsh (6th August, 2019), incar (9th August, 2018), kebappa (3rd November, 2018), motocarlos (11th January, 2021), ovidiumarin (14th June, 2018), svallecilla (8th April, 2020), Tigmaker (10th February, 2018)
can someone share segger j-link software for china clones, I found some versions but cant connect to CP
Thanks dear Friend,
I received my second CP, and I can connect to new carprog, programming is done. ( Without erase Atmel, and remove AT88SC)
but I cant still connect to my old CP, paid new AT91SAM7S256 AU C ( original is AU B ) , still same result, cant connect
do you any idea what parts can be broken ?
Did you try to erase Atmel?
Yes Dear Friend, Atmel has been 3-4 times erased ( from 5 seconds, to 10 minutes ) ,tried also with new blank atmel chips , still cant connect to cp
what parts can be broken?
but I can connect my new CP without erasing content of atmel,,flashing is done with succes ( erased from the menu of Jlink)
[QUOTE=dadal;3205770]Yes Dear Friend, Atmel has been 3-4 times erased ( from 5 seconds, to 10 minutes ) ,tried also with new blank atmel chips , still cant connect to cp
Hi, I'm sorry to tell you.
rasoboy (7th March, 2018)
