Page 33 of 65 FirstFirst ... 23282930313233343536373843 ... LastLast
Results 481 to 495 of 971
  1. #481
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by badziewo View Post
    Is it possible to read Nissan Murano airbag module infineon processor with clone carprog by OBD?
    I doubt it since they moved those function to online..With clone you will get error for fail to connect or something like that but it wont go through.
    🔥Wacka Wacka 🔥
  2. The Following User Says Thank You to FxShaw For This Useful Post:
    badziewo (7th March, 2018)
  3. #482
    Mar 2018
    Hello. I recently purchased a Carprog clone v10.05 off of ebay. Will this be able to perform an airbag reset on a 2015 4runner?
  4. #483
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by ProffesorX View Post
    Noooooooo way
    🔥Wacka Wacka 🔥
  5. #484
    Mar 2018
    Quote Originally Posted by FxShaw View Post
    Noooooooo way
    Ok, thank you.
  6. #485
    droidwayne65's Avatar
    Aug 2015
    North America
    Anyone had any luck reading a Benz W211 285 001548 SRS module with a CR16MCxx mcu? I'm having a time of it; k-line times out, it can read and clear codes via obd but cannot clear crash data. Oh, it's a V9.31 clone.
  7. #486
    Aug 2015
    North America
    Quote Originally Posted by droidwayne65 View Post
    Never mind. Dug out the old V4.74 and it sailed right through.
  8. #487
    dimet's Avatar
    Mar 2010
    MKD
    I have problem to extract files from post 3. Please help
  9. #488
    badziewo's Avatar
    Feb 2016
    Universe
    Use this to split files
  10. The Following 3 Users Say Thank You to badziewo For This Useful Post:
    adamwajda (21st July, 2021), dimet (19th March, 2018), FxShaw (19th March, 2018)
  11. #489
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Thanks but it's going to be the same thing...all the split files still have to be in zip format to upload...he will just have to figure it out..instructions on there and others d/l it with no issues.
    🔥Wacka Wacka 🔥
  12. The Following User Says Thank You to FxShaw For This Useful Post:
    badziewo (19th March, 2018)
  13. #490
    dimet's Avatar
    Mar 2010
    MKD
    Ok it is done
  14. #491
    speedy100's Avatar
    Jul 2010
    Athens
    Hello,
    Mine is original but nothing like the pic of FxShaw above.
    There is no board at all just wires going straight to the corresponding pins according to the diagram plus the two resistors and the diode. Here is original schematic: http://codecard.eu/carprog/adapters/a10-carprog-motorola-mpu-programming-adapter/prod_73.html
    I must say though that i have this tool for about 10 years now but was never able to read and write any Motorola MPU and no Ford air tool is working either on the bench or via OBDII as it Writes but never verifies OK as many bytes are always different. It is to my big disappointment for such an expensive tool... I was asked to send it back for service but need the rest of its services so i never did. Checking it though with A9 all tests pass OK!
    I gave Up and use X-Prog for most work as it is much more reliable...
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  15. #492
    Nov 2015
    CARPROG (original) and RENESAS srs unit : version 11.13 online
  16. #493
    Nov 2017
    Hi.
    I want to make a psg16 adapter. The same that the we can see in the webpage of carprog.
    My question is:
    Is it necesary the relay or I can make conection without the relay? I dont see the diference
    Regards
  17. #494
    Jul 2009
    Switzerland, Wikon
    Hello Friends!
    I've managed to destroy my Carprog (clone) with a short circuit (accidently) on the PCB while it was running
    I killed the AT91 + AT88SC.
    I changed and reprogrammed the AT91, but now, how i can get a working AT88SC Crypto memory? Is there still no solution yet?
    I can lend a Beeprog+ from a friend. Can it write this Chip?
    I found only one Dump for the AT88SC, but i still don't know if this dump works or not.
    Can somebody help me?
    BR Matthias
  18. #495
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Quote Originally Posted by kostelectronics View Post
    Hello Friends!
    BR Matthias
    Buy a new Carprog. The simplest way
    Press Thanks and Reputation
