hello,
can not download carprog 8.21 from # 4 not completely, only file 2 + 3.
can someone send me file 1 + 4 or the complete program?
Thank you
hello,
Thank you
hello.
orrect me if I am wrong, I to change the version I have to change the firmware right, I see that I have switch cable components for it to work fine?
the version I have is 9.31 clone and the lib file. 081105caroo1773l but it is not working all its functions.
thank you
carprog clone can do honda air bag reset tms320?i follow diagram also cannot clear crash...
gonzcaal (24th October, 2017)
need help:
for clone I have 7.8 and 9.3 clone carprog software versions
trying to do 2013 Nissan Altima with infineon XC2336B-40F mcu,
with clone carprog,
when trying to read get error: "fail to connect to remote server"
(I also have one real caprprog but fir that one I didnt buy any software yet, only adapters A1 multi and GM )
Hello.
I'm confused with my china clone 8.21. I have red many things about fixing carprog clones but I haven't found a good solution to my problem. Last mod I made was changing HCT125D's to Texas Ins. HC125M. Original ones where Phillips 74HCT125D. After this done U11 got super hot and I disconnected usb.. Can somebody post pictures what to do on board please.. New 125's where checked by the supplier that they are correct type and I soldered them on just like the old ones where in the board..
What's going on with this thing, any Ideas??
Hello,
I would like to connect carprog with delphi delco hsfi 2.1 ecu (opel astra g - z14xe) on the table . Do i have to use the A15 cable ? Does the A15 cable has electronics inside or is just a connector with wires ? Is there a way to find the A1 adaptor schematics ?
ecufix (16th April, 2020)
hi, my carprog have a CAN communication problem it dosn't communicate with any device ,the K-line communication is good
i have update my adapter A1 (all changed resistor,capacitor, mcp...) but still no result ?? any help please,thanks...
i have see v10.05 china copy, what is difference from old one ?
Sorry if this was asked before or dumb question but I can’t find answere anywhere.
(I have original carprog and clone carprog but mostly use original because clone works very bad.)
What is “ carprog units “ ? Every time I start carprog software and read eeprom I get “.. number of units left connect to synchronize “ and eveytime the number is less and less.
Counter left...
Keep in mind, English is not my native language.
hello friend after I programmed the flash of my carprog, he le km more do not write
can you help me?
Carprog vs Motorola HC 12 mask 0K75F
Press Thanks and Reputation
