Page 10 of 26 FirstFirst ... 5678910111213141520 ... LastLast
Results 136 to 150 of 387
  1. #136
    roth18's Avatar
    US
    Quote Originally Posted by thebigk View Post
    I was told that with autologic you cannot flash a new FRM3 module, this is for 2010 BMW X5 M 4.4i
    I am wondering if auothex can do the job?
    Many tools can do it including Autohex BUT Autohex went that extra mile and translated the coding options (in case you want to change them), which makes a life a bit easier.
    Best Regards, Roth.
  2. #137
    Aug 2016
    hi,
    can autohex 2 relearn,adapt, program smg1 , smg2, smg3 and dct3 transmission ? Thanks !
  3. #138
    Default AutoHex II BMW Diagnostic Software Version 1.0.41
    On Bench Functions
    Autohex II BMW Diagnostic software update is available for Autohex BMW users.
    • On Bench Functions: ISN Manager, CAS Firmware, Key Programming, FA manager, and Read/Erase Fault codes are available now, users don't need a valid FA to use these functions.
    • More F series ISN can be retrieved by OBD in this version (more for Europe, U.S.A, and China versions).
    • A Major enhancement in WVCI HW3, users are more safe while programming BMW Ecus even if USB disconnected for few seconds.
    • Coding and programming data for E series have been updated.
    • Fixing minor coding problems for new DMEs in F series.
    • Enhancing Ecu flashing in F series.
    Important Note:
    On Bench cable must be made by users, Autohex II HW3 Tricore cable will not work for these functions.
  4. The Following 5 Users Say Thank You to djollie For This Useful Post:
    Ebie (14th March, 2017), Levanime (22nd February, 2017), mexjack (23rd March, 2017), PremierD (22nd February, 2017), roth18 (21st February, 2017)
  5. #139
    May 2016
    • Updating Ecu programming and Ecu coding for F series
    • Adding more DME ISN read/write by OBD for F series
    • Fixing a problem while flashing some EGS part numbers in E series (E65)
    • Optimized F series programming.
  6. The Following 2 Users Say Thank You to Levanime For This Useful Post:
    decno1 (2nd May, 2017), PremierD (2nd May, 2017)
  7. #140
    Oct 2016
    Hi Everyone
    Is there a distributor on South Africa for Auto Hex ? Where can I buy this tool? I have sent a email to MicroTronik but they did not reply.
  8. #141
    Dubai
    We have a reseller in South Africa, you can contact Microtronik to get his details.
  9. #142
    AutoHex II BMW Diagnostic Software Version 1.0.43
    BMW F series manual coding
    • Manual coding for F series is available in this version.
    • Enahnced USB driver for a better performance in F series flashing.
    • BMW F series 8HP EWS Reset is ready to be used by all users.
  10. The Following 2 Users Say Thank You to djollie For This Useful Post:
    decno1 (21st June, 2017), PremierD (21st June, 2017)
  11. #143
    Moderator
    PremierD's Avatar
    Jun 2009
    Also I have been reliably informed that the original and the best forum members will receive a discount on this excellent product
  12. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    decno1 (21st June, 2017), doctore (21st June, 2017), Faraday (27th July, 2017), vanos batam (28th July, 2017)
  13. #144
    Newbie TOM8O's Avatar
    Jul 2017
    Stoke-on-Trent
    I have a technical question regarding cas programming.
    If I use winkfp or ista I have to switch ignition off and remove key from the slot.
    Autohex did not ask me to do it. Is that right?
  14. #145
    Dubai
    It is required only if you want to flash CAS in E series, and Autohex II will ask you to remove the key.
  15. #146
    Moderator
    PremierD's Avatar
    Jun 2009
    Came across this .... comments welcome
    https://www.facebook.com/microtronik...6490446419512/
  16. The Following 5 Users Say Thank You to PremierD For This Useful Post:
    decno1 (17th August, 2017), djollie (18th August, 2017), doctore (31st August, 2017), Weasel3 (18th August, 2017), wiseman (17th August, 2017)
  17. #147
    hello members,
    check out our blog page for the latest news on hardware 4.
    http://www.microtronik.com/blog/
    also take a look at the video for FEM/BDC security unlocking.
    https://www.facebook.com...videos/1436490446419512/
  18. The Following 2 Users Say Thank You to djollie For This Useful Post:
    doctore (26th September, 2017), Weasel3 (18th August, 2017)
  19. #148
    Faraday's Avatar
    May 2012
    The dark side of the moon
    When will you relase
    AUTOHEX II HW 4 ?
  20. #149
    Moderator
    PremierD's Avatar
    Jun 2009
    Mouth watering prospect mate .. isn't it ..
  21. The Following User Says Thank You to PremierD For This Useful Post:
    decno1 (19th August, 2017)
  22. #150
    AutoHex II BMW Diagnostic Software Version 1.0.44
    Autohex II BMW Configuration
    • BDC and FEM key programming is ready for Autohex II HW4. The function can be executed from CAS Firmware, it will generate a secret info file, then it will return the BDC/FEM back to exactly the original state. Autohex II BMW users can use the key programming function to make a key for FEM or BDC modules after they retrieve the secret info file.
    • BMW configuration with useful options is available now. Expert mode can be activated by the user from this window. more information about these options can be found in our blog.
    • French, Spanish, Portuguese, Chinese and Korean languages are fully supported now. German and Turkish are available only in diagnose functions.
    http://www.microtronik.com/blog/auto...onfigurations/
  23. The Following User Says Thank You to djollie For This Useful Post:
