Page 12 of 26 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 387
  1. #166
    roth18's Avatar
    US
    Did anyone try to recover FRM3 with Autohex but ON THE TABLE??? The flash gets corrupted in it so theoretically it should be possible.
    Best Regards, Roth.
  2. #167
    Dubai
    Hi Roth18
    Although we have not test FRM on Bench, I think if you are using a JBE and CAS and FRM with the correct FA you should have no issue in flashing FRM,
  3. The Following 2 Users Say Thank You to decno1 For This Useful Post:
    doctore (10th December, 2017), roth18 (7th December, 2017)
  4. #168
    magneto21's Avatar
    Jul 2016
    if you have x-prog orig..... or clone
    you can do it , is very easy ,
    all you need , you can find on DK....
  5. #169
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by roth18 View Post
    I dont think it would be possible as how would Autohex know the correct FA?
  6. #170
    Jul 2016
    I’m looking to buy autohex in the next few days, for cas4 can i use autohex to program by obd or do i need to still read cas eeprom?
  7. #171
    Dubai
    CAS4 and CAS4+ yes you need to read eeprom
  8. The Following 2 Users Say Thank You to decno1 For This Useful Post:
    doctore (10th December, 2017), iHenry3 (13th December, 2017)
  9. #172
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    just had a continental msd81 flash erased while reading ISN with AVDI. question is would autohex have been possible to fix this?
    see it has tricore reading ability - could i have copied data from another ECU ?
    I am a FUD
  10. #173
    Dubai
    If you erase it by obd the chances are very high.
    If by boot mode (first flash sector is erased), I think it is impossible to be recovered because ISN and otp passwords are stored there.
  11. #174
    Dubai
    AUTOHEX BMW Version 1.0.47
    A new enhanced software version is available for all BMW Autohex users which rectified all issues regarding FEM/BDC unlock and more stabilized for programming ECU using E-net. Unlike the old versions getting secret file from FEM/BDC can be done all on bench. No need to go for advanced option for unlocking. software has become 100% safer and stable for programming FEM - GW and FEM - BODY on bench without any working key. Also Ethernet allows users to flash units like HU-H,KOMBI..etc in F series in reduced time period without any error.
    [IMG][/IMG]
  12. The Following User Says Thank You to decno1 For This Useful Post:
    Levanime (21st December, 2017)
  13. #175
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Can I code FEM from dealer in F30 2014 with autohex?
  14. #176
    Dubai
    You mean a new FEM? If yes, the answer is you can of course.
  15. #177
    roth18's Avatar
    US
    Guys, anyone is getting code 834f on 11% when flashing modules ??? I have a MSV80 here on which I was trying to confirm the SK that I changed. Autohex cannot read without update and update cannot complete. Now I have 2FA3 DME: No coding DTC in the DME.
    Best Regards, Roth.
  16. #178
    roth18's Avatar
    US
    Trying to encode the DME with Autohex gives me error 8112 .
    Best Regards, Roth.
  17. #179
    May 2016
    turn ign on
  18. #180
    Jul 2016
    Ok taking on a big project, Customer purchased a bmw 2017 440i and it was completely flooded, which module need to be replaced to get the car running. I was thinking DME & FEM what else would you guys suggest?
