Page 15 of 26 FirstFirst ... 5101112131415161718192025 ... LastLast
Results 211 to 225 of 387
  1. #211
    Quote Originally Posted by i-vtec View Post
    @decno1 can you upload Read-write ISN, VIN Bosch MEVD17.2.3 BMW because is out
    some idiot has flagged this video for music copy right...i'm sure it will be relisted minus the music
  2. The Following 3 Users Say Thank You to djollie For This Useful Post:
    doctore (21st October, 2018), phuckyall (23rd October, 2018), PremierD (17th October, 2018)
  3. #212
    jodge's Avatar
    Mar 2017
    i don't like the Mini cas. At all.
    So.. i'm doing research
    Can i ask some feedback, experience..etc
    i'd like to minimize the risk and it seems the autohex pricey but worth it
    thx
  4. #213
    Apr 2017
    Default >>>>>>Autohex II Support Thread<<<<<<<
    Quote Originally Posted by Faraday View Post
    this is the safest solution to drill, do not try to open you will destroy ECU
    Verzonden vanaf mijn iPhone met Tapatalk
  5. #214
    doctore's Avatar
    Nov 2015
    Colorado Denver
    the best bmw tool and do not worry about mini and other , you can do them without stress
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  6. The Following 2 Users Say Thank You to doctore For This Useful Post:
    djollie (23rd October, 2018), jodge (21st October, 2018)
  7. #215
    Mar 2009
    Not quite true. I'm currently having some stress with a CAS based Mini, 2013.
    Looks like it got updated at the dealers last year. Clever person blocked all but the first two keys. Then sold the car. New customer lost all keys. Then ordered a dealer key but it will not start car. Cannot unblock the keys, as need a working key to do this. Cannot read the ECU ISN on the car, MEV 17.2.2. Software gets to 10% and then says 100% then no ISN, yes hazard light and break pedal, etc. So either I'm doing something wrong or there is a problem.
    Also currently got a problem with a BDC based 2014 Mini I'm working on. Cannot read the secret info from the BDC, even with the ISN. Hopefully the imminent update will fix this. Yes, I know BDC cracking is new tech, just not sure I'll do another one for a while with the way this one is going.
    I'm not saying that Autohex isnt the best tool out there, but to say you wont have any problems is perhaps an overreach. I've done lots of keys to CAS based BMW that AVDI struggled with. Let alone ECU, ABS and CAS swaps that would not have been possible without Autohex.
  8. The Following 2 Users Say Thank You to madaxe For This Useful Post:
    djollie (23rd October, 2018), jodge (23rd October, 2018)
  9. #216
    jodge's Avatar
    Mar 2017
    i don't expect the perfect tool
    I saw the mikrotonic videos, read the manuals...forum etc. But I would be more interested in what is not written
    CAS3+ encypted functions The usual way is downgrading the cas firmware. As i see there is one button downgrade and upgrade (with PSU of course)
    But there is a big warning
    Always make backup using tools like BDM before doing CAS firmware for these part numbers
    Let's assume there is a tricky version Mini stopped under the downgrade. (avdi, cgdi, vvdi..something) They towed into my shop. How can i bring back with autohex?
  10. The Following User Says Thank You to jodge For This Useful Post:
  11. #217
    Mar 2009
    I dont have a lot of experience with the problem you mention. It depends on where things got interrupted I think.
    If module gives a part number, and you have the ISN, I'd expect Autohex to recover it by OBD. I've coded 2nd hand module, updated flash and changed VIN on CAS and other modules without problems.
    If no part number by OBD, I'd think you need to flash the module with a programmer, and then ISN to ECU. Then coding from backup module.
    I doubt dealer keys will work in future if the key data was damaged, but certainly you should be able to make a key to start it with Autohex.
    Im sure more knowledgeable people will point out errors in this.....
  12. The Following 2 Users Say Thank You to madaxe For This Useful Post:
  13. #218
    Mar 2009
    Looks like my problem with the Mini 2014 BDC got fixed in the last big update. Car starts broom broom!
    Anyone planning the update should allocate an hour as its a complete uninstall/reinstall, inc all BMW data.
  14. #219
    Moderator
    PremierD's Avatar
    Jun 2009
    New to some .. not to others I guess ..
  15. The Following User Says Thank You to PremierD For This Useful Post:
    doctore (27th January, 2019)
  16. #220
    Dubai
  17. The Following 4 Users Say Thank You to decno1 For This Useful Post:
    djollie (22nd January, 2019), doctore (27th January, 2019), Faraday (25th January, 2019), PremierD (23rd January, 2019)
  18. #221
    doctore's Avatar
    Nov 2015
    Colorado Denver
    News
    Autohex II BMW Lite Locksmith with HW4
    What you get:
    • Autohex II Hardware WVCI HW 4
    • The powerful HexTag BDM and Key programmer.
    • BMW Software Lite Locksmith License
    • Key Programming License
    • BMW ISTA/D driver to run dealer software
    • 1 year technical support
    • 1 year hardware warranty
  19. #222
    Default AutoHex II BMW Diagnostic Software Version 1.0.54
    FEM/BDC Replacment
    Autohex II BMW Diagnostic software update is available for Autohex BMW users.
    • A new function for replacing FEM/BDC (including key transferring from original to donor) is available in this version, users can use this function from CAS replacment.
    • Deleting keys from CAS4,CAS4+ FEM and BDC is available in this version, users can use this function from key programming.
    • Fixed the FA parsing for new models (2018-2019) in F and G series.
    • Turkish language is supported starting from this version.
    • Other languages is updated in this version.
  20. The Following 4 Users Say Thank You to djollie For This Useful Post:
    bry0sb (3rd February, 2019), doctore (3rd February, 2019), madaxe (4th February, 2019), PremierD (3rd February, 2019)
  21. #223
    Default FEM/BDC unlocking without key and ISN
  22. The Following User Says Thank You to djollie For This Useful Post:
    PremierD (5th February, 2019)
  23. #224
    sdnatlst's Avatar
    Aug 2011
    England
    How much is this package, where can i find it?
    because it is LITE version, does that mean it will still do all CAS3 work and encryption add keys etc, downgrade if needed etc.
  24. #225
    Apr 2016
    uk
    Quote Originally Posted by sdnatlst View Post
    Here are all packages available...
    https://www.microtronik.com/order-online/
  25. The Following User Says Thank You to comizelu For This Useful Post:
    sdnatlst (6th February, 2019)
