also, does the LITE package support removing CAS unit and adding keys direct with the hextag ? or no ?
thanks, yes found it!, microtonik are safe to order from with paypal? does china holiday affect their shipping do you think? thanks!!
i currently have CGDI BMW only for couple of weeks, and already a couple of cars i arrive with CAS3 it says "cas unsupported" ,,, so to stop wasting time i am going to buy this.
i hope it supports many more CAS3 and can safely downgrade istap+ !
holbi1 (23rd November, 2019)
I don't have it.i have vvdi2 and cgdi but I still don't touch any BMW after 2007!
Have a friend who ordered via PayPal.arrived in UK without problems and low customs taxes.he have the full version.
Very good support and very good tool-- his feedback..
I will buy it as well but want the full version.
i only need to add keys to cas3, so think lite version will work for me
when you get it, will you do bmw after 2007? i guess you dont want to risk downgrade with CGDI,,, like me?
Obviously I'll try all kind of keys first.all case types and fem.
Have a few friends with BMW's waiting for me to get autohex than will do customers keys..
The friend who got it already programmed a cas3++,a used one on a 3 series.
Only issue,his fault,instead of automatic transmission he programmed as manual.
Car wasn't even cranking because waiting to press clutch.contacted support and after 1h they were on TeamViewer,found issue and everything ok.
They also downgraded cas programmed key and upgraded back CAS.
30 minutes maybe
Car started no issues
sdnatlst (7th February, 2019)
amazing,,, i really will find it useful on MINI cas which is very long removal process when encrypted to downgrade, add key and upgrade again! all my obd
Hello folks,I have a question (maybe stupid)but need to clear.The last software version has the capacity of extract ISN of Fem,if I extract the ISN of just the FEM and make the key,if all keys lost,the car star with that key?
once you extract the secret file you can make key, change isn, mileage etc
I would like a straight answer on this also.
If I have all keys lost on an F series, is it now easier to make keys than removing the ECU, drilling a hole and reading the ISN by boot mode?
If so, how?
PremierD (9th February, 2019)
Every F series I have done with AKL I have had to drill a hole to access the boot PIN on the ECU to extract the ISN.
It's that much work that its not worth doing, just order the key from the dealer.
When somebody develops a way of doing it easily, I'm sure they will make a big fuss about it.
As it stands, it does not look like anybody has.
