Page 8 of 26 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 387
  1. #106
    Oct 2015
    here is the CODING and the Programming Report....
    My colleague went through and updated every single module in the car... Now the CID doesn't work at all, doesn't displaying anything.... oh boy....
    any suggestions?
  2. #107
    Moderator
    PremierD's Avatar
    Jun 2009
    And when you contacted support ..Microtronik .... what did they tell you ???
  3. #108
    Oct 2015
    Quote Originally Posted by PremierD View Post
    they said replace all the modules
  4. #109
    Oct 2015
    Quote Originally Posted by thebigk View Post
    The weird part is the shop owner replaced several modules 2 years ago due to water damage, but the car always had "not programmed correctly"
    I think he should of replaced the CID at the time, but since the insurance covered everything. Now the car owner is holding him responsible and I am trying to help him out.
  5. #110
    Dec 2009
    Dubai
    We did not say to replace all, replace as a start the MASKG which has a wrong Hardware Reference.
  6. #111
    Apr 2015
    canada
    hello decno1 currently a 750li f01 just got towed to our shop i was wondering if autohex will support all keys lost on cas4
    all key lost situation
    or we should just order from dealer
    i have full package of autohex ii
    havent tested any key programming for cas 4
  7. #112
    May 2016
    I dont speak for AutoHex2 support
    but
    this is from AutoHex2 forum:
    I advise you do the following before you go to CAS EEPROM reading.
    1- Go to key programming, and check if CAS EWS5 is active or not (if Not jump to 4).
    2- If EWS5 active, please check if you can read DME ISN by OBD.
    3- If you cannot, check if it is Bosch or continental, if Bosch, then you can use the tricore boot mode to read the ISN. If Continental... forget about it (at least for now).
    4- Read EEPROM from CAS
    5- Use Autohex II to complete the bmw key programming procedure . if EWS5 is active you will be asked to input the DME ISN.
    You can do nothing when CAS4+ got a corrupted EEPROM. the only solution after that is buying a new CAS.
    Obviously, if you are lucky and DME is BOSCH, then you will need programmer to read CAS EEPROM and then AutoHex2 will handle it without problem
  8. #113
    Oct 2015
    If I could make a suggestion... I think a nice printable report of available Program updates and performed updates would be really beneficial. I am left with screenshoting, and just kind of doing a lot of work that could be probably easier if integrated. This would make selling computer updates easier to our customers, which means more money to give you guys
    any suggestions?
    Replaced M-ASK module, recoded.
    Still had hardware reference error for CID but the error message went away and everything works now.
  9. The Following 2 Users Say Thank You to thebigk For This Useful Post:
    decno1 (7th October, 2016), GameTheoryOptimal (20th October, 2016)
  10. #114
    Dec 2009
    Dubai
    More money trigger will let's think seriously about your suggestion
    You still have a problem with your MASK, if it is working without fault codes, just NEVER try to program it in expert mode.
  11. The Following User Says Thank You to decno1 For This Useful Post:
  12. #115
    AutoHex II BMW Diagnostic Software Version 1.0.39
    Autohex II BMW ISN boot mode for DDE 741
    Autohex II BMW Diagnostic software update is available for Autohex BMW users.
    BMW Ecu programming data has been updated in this version.
    Fixing problem in saving keys in E series: Some specific part numbers , Autohex II was unable to save the key data.
    Adding more options in ISN function for MSD80,MSD81,MSD85,MSV80,.. : users can save the Tricore password (to be used in ISN boot mode later) as well as they can avoid the DME update before they can read ISN.
    BMW ISN Boot mode (Tricore): DDE741 is available now.
    BMW FA Manager in F series: English text is available for all FA elements in F series.
  13. #116
    GameTheoryOptimal's Avatar
    Jun 2016
    Canada
    quick question for those who have autohex2, or even better to support/developper team...
    is that tool able to read/write ISN in EGS from a 2012 BMW E70 with 8 speed transmission? (8HP)
  14. #117
    Dec 2009
    Dubai
    8HP is not supported yet.
  15. The Following User Says Thank You to decno1 For This Useful Post:
  16. #118
    May 2016
    AutoHex II BMW Diagnostic Software Version 1.0.40
    • CAS Firmware has been enhanced in this version, users can restore CAS downgraded back to original status.
    • ISN Boot Mode for MSD80, MSD81, MSD85 is available now, users can read and write ISN in these Ecus.
    • Correcting a software bug in DSC coding in some models of Mini Cooper.
    • Enhancing ISN read/wriet in E series.
  17. The Following 2 Users Say Thank You to Levanime For This Useful Post:
    decno1 (3rd November, 2016), djollie (2nd November, 2016)
  18. #119
    Dec 2009
    Dubai
    A video shows how to change DME MSD85 by Autohex II.
    We assumed that original DME is not responding, and of course the EGS is 8HP.
  19. #120
    Autohex 2 for Hyundai/Kia GDS
    Anyone here running Autohex with the GDS for Hyundai, I would like to make contact with.
    email *Removed Email Address...
