Page 1 of 26 12345611 ... LastLast
Results 1 to 15 of 387
Hybrid View
    Moderator
    PremierD's Avatar
    Jun 2009
    Default >>>>>>Autohex II Support Thread<<<<<<<
    A new support thread people ... lets have some feedback please .
  2. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    djollie (12th August, 2015), maybach_ (18th March, 2016)
  3. #2
    Been using this for the last month or so, very good for BMW. We have used it in various vehicles for the following procedures:
    Diagnostics
    Flashing
    ISN Read
    Replacing ECUs with donor ECUs from other vehicles.
    ECU doesn't have to be the same part number and this tool auto corrects the coding for the vehicle.
    The best thing about flashing is that it has True Expert mode allowing you to program and code individual modules unlike ISTA-P Expert Mode were it will auto add other modules even though you have taken them out the measure plan.
    The diagnostic side of Autohex II on par with ISTA-D but it has a much faster operational time. Incidentally it can be used as a pass-through device for ISTA.
    As far as support goes, anytime I have needed help, they have been able to come on via TeamViewer and guide me through the process.
    I see that some members already have this tool so hopefully they will get involved.
    I will be adding to this thread over the coming months with content like videos and tutorials of how to use this software. If you have any questions regarding this tool then feel free to ask and I will get back to you. I would like to grow this thread so everyone using this tool has a place for discussion, and where needed support .
    Here is a quick step by step for ISN read:
    ISN changing for CAS3+ having BMW Partnumber: 9262360,9262361,9262361,9267609,9287534,9287535:
    1- Go to FA Manager, select button 1 (Save CAS FA Into FRM or LM)
    2- Go to CAS Firmware, and do CAS firmware, this will take about 7 minutes.
    3- Go to ISN Manager and do the ISN / SK change you would to.
    4- After finishing ISN / SK saving, you MUST, either:
    A- Disconnect CAS and connect again (Unpower / power again)
    B- Or, disconnect battery cable and connect again.
  4. The Following 5 Users Say Thank You to djollie For This Useful Post:
    decno1 (9th August, 2015), decoderman (28th November, 2017), hagop1 (15th August, 2015), MV auto (14th April, 2016), weltune (10th July, 2016)
  5. #3
    Jun 2010
    I have a question about autohex:
    2 days ago I was trying to replace airbag in E60 2008.
    The program showed me in the list of Programming ECU that this airbag is not compatible, however I asked Autohex to continue.
    After Autohex starts in about 1 minute it showes error message "Security Access Error, please check conditions"
    Is there a way to come over this problem?
    By the way few months ago I did same in other car, but it worked, the VIN has changed and airbag part number has changed to became matching FA
  6. The Following User Says Thank You to Taljemotors For This Useful Post:
  7. #4
    Dec 2009
    Dubai
    You are using a different airbag which does not belong to E60. please select another airbag that should be for E60.
    You got a warning message from Autohex informing you this airbag not compatible, and I think you get another warning telling you hardware not compatible, but you decide to continue.
    Anyway, this airbag still functioning and can be used in the proper car to be flashed.
  8. The Following User Says Thank You to decno1 For This Useful Post:
  9. #5
    Mar 2011
    Hello ,
    I have damaged DME MSV70 in E60, the ECU I used to replace is different part number.
    after I change ISN I see fault code (Incorrect data)
    what wrong I did?
    thank you
  10. #6
    Dec 2009
    Dubai
    Just to make things clear for me.
    You read ISN from DME, then write this ISN in CAS, then DME-CAS Adjustment, then Engine runs...
    After that you just go to fault codes, you got this error, if I am correct then you must do the following:
    1- Encode the DME, then check the fault, is still present, go to 2
    2- Flash the DME, and encode it again, if Autohex II shows you in programming list (ECU not compatible), then .. PM me your email address and you windows version (32/64) so I can activate for you the advanced programming in Autohex BMW, this will let you program the DME the correct flash that matches the FA.
  11. The Following 3 Users Say Thank You to decno1 For This Useful Post:
    djollie (16th August, 2015), hagop1 (15th August, 2015), MV auto (14th April, 2016)
  12. #7
    Mar 2011
    ok thanks I will try it and then post results .
  13. The Following User Says Thank You to hagop1 For This Useful Post:
    decno1 (14th August, 2015)
  14. #8
    Apr 2015
    canada
    hello all autohex users.
    hope you all like it,i own various tools..i must auto hex is good
    yesterday we had a 745li 2004 bmw
    dme problem
    it took us less then 10mins to program a used ecu,i used to read and write way too much work and risk of damage to hardware..but this tool made our work very easy.
    tools owned
    1.avdi bmw full
    2.autel maxisys
    3.launch
    4.autologic bmw
    5.autologic mercedes
    6.autologic vag
    7.avdi for chrysler full
    8.zed full
    9. digi master 3
    10. auto hex ii just 2 month and very happy with there support also very quick response... keep it up
    microtronic auto hex ii
  15. The Following 3 Users Say Thank You to infotech For This Useful Post:
    decno1 (13th August, 2015), djollie (16th August, 2015), MV auto (14th April, 2016)
  16. #9
    Apr 2015
    canada
    procedure 2004 745li
    install used dme
    read 8bit isn code
    read isn in cas
    write isn read from used dme into cas
    go in to service-DRIVE-dme-cas adjustment/alignment DONE DEAL!!
  17. The Following 2 Users Say Thank You to infotech For This Useful Post:
  18. #10
    Aug 2014
    Australia
    Hi guys ,
    I've personally had autohex for about 2 months and luckily I've had 3 cars to play with.
    First car was a Bmw e90 faulty DME I purchased a x3 DME with matching numbers and read isn and coded vehicle and could not believe it worked with such ease !!!!
    2nd vehicle was also an e90 although this time it was a MSV80 😱😱as I've tried doing this with competitors tool before without success or SUPPORT bit I'm not hear to bash on thee tools!
    But it was just as easy to do ,
    As for the third it was today's main event it was a e70 with water in DME
    so I got a DMEwith same numbers read and write CAS as usual go to diagnose perform CAS-DME adjust car started peformed EGS/EWS SYNC and this car was ready to go !!!!!! That's something I couldn't do before and it's a $1000 option on other tools 😉
    I've had to contact the team at MICROTRONIK to explain how to do something's and WOW WOW WOW is all I can say these guys are EXCELLENT freindly and very helpful
    I honestly think this is my best euro tool investment !!!!!
    Very fair price
    Too cheap compared to others
    I think it's performance is a new bench mark !!!
    Thank you to the team a MIKROTRONK
    for such a great tool
    And I look Forward to what's To come in the future from you !!
  19. The Following 5 Users Say Thank You to Airbags plus For This Useful Post:
    csavargo2 (11th January, 2016), decno1 (14th August, 2015), djollie (16th August, 2015), GameTheoryOptimal (24th August, 2016), MV auto (14th April, 2016)
  20. #11
    Mar 2011
    hello I send you serial for my device , so I can update this ecu .
  21. #12
    Autohex II Key Programming
    BMW Key Learning Main Functions
    Autohex II is the best solution for those who are looking for a single tool that solve all cases in BMW key programming.
    With the equipped functions for key learning in BMW software, users can read, write, block, unblock,save and delete any key in the CAS.
    Autohex II is advanced tool for Encrypted CAS (CAS3+), users can add new key with or without working keys available for all versions of CAS3+.
    After selecting Key learning from the left list, user will get a list of available functions as in the picture.
    Here's a quick vid demonstrating key programming on an m6.
  22. The Following 2 Users Say Thank You to djollie For This Useful Post:
    decno1 (18th August, 2015), MV auto (14th April, 2016)
  23. #13
    Pro Diagnostic Solutions's Avatar
    Aug 2015
    Glasgow
    This video is a brief introduction and overview of Autohex II, showing the functionality of the software and the menu layout.
  24. The Following 2 Users Say Thank You to Pro Diagnostic Solutions For This Useful Post:
    decno1 (18th August, 2015), djollie (17th August, 2015)
  25. #14
    Aug 2015
    Glasgow
    The second video shows how to perform a complete diagnostic scan of the car, how to delete trouble codes and reading live values from the car.
    I plan on making more videos in the future to build up a repository of guides for all Autohex II owners to refer to for any task they are unsure of. Please keep in mind this is a continuous development aimed at aiding the Autohex II community.
  26. The Following 5 Users Say Thank You to Pro Diagnostic Solutions For This Useful Post:
    decno1 (18th August, 2015), djollie (17th August, 2015), garagetech (31st August, 2015), hagop1 (18th August, 2015), pauld5152 (14th January, 2016)
  27. #15
    Mar 2011
    hello,
    today I was very happy with wireless function ,
    there was a lot of cars at my work shop and no place to stop a car on the side walk, I had a customer who wants to replace a bad working ecu-ms45.1 for e 60-
    I was busy programming another mb cas on my laptop , so I thought let me try the wireless function , the damaged car was in the middle of the road , so I quickly exchanged the good ecu from junk and made adjustment and the car started . it took about 4 min and I was don.
    no other device like autohex2 has this function .
    it got me easy money very fast.
  28. The Following 2 Users Say Thank You to hagop1 For This Useful Post:
    djollie (20th August, 2015), MV auto (14th April, 2016)
