Autohex II version 1.0.25 has been released and here are the following changes:
- Autohex II can change used DME in F series starting from this release (by OBD II).
- ISN 128 bits (SK) in DMEs of E series, can be modified, users can change DME ISN besides the ability to write it into CAS.
- ISN in DMEs of F series, added the ability to flash the ECU to retrieve the DME ISN.
- Key learning in F series: Enhancement for the case CAS4+ encrypted (EWS5)
AutoHex II Software For BMW Version 1.0.27
Autohex II BMW software version 1.0.27 is available for Autohex II users.
- Adding support to change DME2 ISN in F series.
- Optimizing Key learning for F series CAS4+ EWS5.
- Optimizing coding for F series to be faster.
- For more secured programming, Autohex II will prohibit flashing if laptop/tablet battery not charged enough.
hello guys...
my problem is we have swap a s63(m series) motor with orginal n63 motor
on 2010 x6
we change the dme which came with the motor s63
after programming with autohex ii
everything start ok but,i get incorrect data code in dme
and engine is in limp mode..
how can i correct this problem...
cas is orginal n63(with FA of n63)
when i go in ecu coding we get ecu not compatible
Under your risk, you can flash the DME after you avoid 2-3 warning messages from Autohex ( this is in case you have advanced programming feature in Autohex).
In your case, the chances are less (if coding shows not compatible too, this means hardware is different too), If I was in your shoes I would find a compatible DME and repeat the procedure with Autohex II.
MV auto (14th April, 2016)
InfoTech: You must be skilled now in Autohex II, is not it?
Hi Decno, do you think autohex will ever allow the user to view the dump from vehicles? Since it is obviously reading the dumps and manipulating them. Being able to edit them, would allow to tune BMW's and also expanding the marketability of the product.
thank you thebigk for your suggestion
If you mean you need to read Data Flash of DME for tuning purposes , the answer is yes, we plan to add such feature.
However, functions to read RAM (some tools call them DUMP), they are useless for users, we have no plan to add such functions.
And what when car is with damaged cas 3, 3+? It is possible to make car run with Autohex II?
ON TOPIC:-
Is this tool only for bmw?
Version 1.0.28 is available
- Totally new flashing and coding functions for E series. This version gives better performance.
- Manual coding has been added in this version
- Work on Bench is totally supported for WVCI HW2.
- Enhancing the function of CAS and DME ISN.
NO LINKS TO YOUR SITE !!!
Last edited by gmb45; 1st March, 2016 at 06:44 PM. Reason: REMOVED LINKS TO HIS SITE
Decno1. Can i make Keys without having car,f. ex. when Client send me cas module. Remote Control will be working? In what cases i cant do key without car.
Best rgs.
benzstop (20th April, 2017)
Good question:
Cases you can make key with CAS only:
- All keys lost and CAS is not encrypted
- Have 1 key and CAS encrypted
- Have the DME along with Encrypted CAS and all keys lost.
You mean i can make Keys without having car with posibilities that you write?
