hi,
can autohex 2 relearn,adapt, program smg1 , smg2, smg3 and dct3 transmission ? Thanks !
hi,
AutoHex II BMW Diagnostic Software Version 1.0.41
On Bench Functions
Autohex II BMW Diagnostic software update is available for Autohex BMW users.
- On Bench Functions: ISN Manager, CAS Firmware, Key Programming, FA manager, and Read/Erase Fault codes are available now, users don't need a valid FA to use these functions.
- More F series ISN can be retrieved by OBD in this version (more for Europe, U.S.A, and China versions).
- A Major enhancement in WVCI HW3, users are more safe while programming BMW Ecus even if USB disconnected for few seconds.
- Coding and programming data for E series have been updated.
- Fixing minor coding problems for new DMEs in F series.
- Enhancing Ecu flashing in F series.
Important Note:
On Bench cable must be made by users, Autohex II HW3 Tricore cable will not work for these functions.
- Updating Ecu programming and Ecu coding for F series
- Adding more DME ISN read/write by OBD for F series
- Fixing a problem while flashing some EGS part numbers in E series (E65)
- Optimized F series programming.
Hi Everyone
Is there a distributor on South Africa for Auto Hex ? Where can I buy this tool? I have sent a email to MicroTronik but they did not reply.
We have a reseller in South Africa, you can contact Microtronik to get his details.
AutoHex II BMW Diagnostic Software Version 1.0.43
BMW F series manual coding
- Manual coding for F series is available in this version.
- Enahnced USB driver for a better performance in F series flashing.
- BMW F series 8HP EWS Reset is ready to be used by all users.
Also I have been reliably informed that the original and the best forum members will receive a discount on this excellent product
decno1 (21st June, 2017), doctore (21st June, 2017), Faraday (27th July, 2017), vanos batam (28th July, 2017)
I have a technical question regarding cas programming.
If I use winkfp or ista I have to switch ignition off and remove key from the slot.
Autohex did not ask me to do it. Is that right?
It is required only if you want to flash CAS in E series, and Autohex II will ask you to remove the key.
Came across this .... comments welcome
https://www.facebook.com/microtronik...6490446419512/
hello members,
check out our blog page for the latest news on hardware 4.
http://www.microtronik.com/blog/
also take a look at the video for FEM/BDC security unlocking.
https://www.facebook.com...videos/1436490446419512/
When will you relase
AUTOHEX II HW 4 ?
Mouth watering prospect mate .. isn't it ..
decno1 (19th August, 2017)
AutoHex II BMW Diagnostic Software Version 1.0.44
Autohex II BMW Configuration
- BDC and FEM key programming is ready for Autohex II HW4. The function can be executed from CAS Firmware, it will generate a secret info file, then it will return the BDC/FEM back to exactly the original state. Autohex II BMW users can use the key programming function to make a key for FEM or BDC modules after they retrieve the secret info file.
- BMW configuration with useful options is available now. Expert mode can be activated by the user from this window. more information about these options can be found in our blog.
- French, Spanish, Portuguese, Chinese and Korean languages are fully supported now. German and Turkish are available only in diagnose functions.
http://www.microtronik.com/blog/auto...onfigurations/
doctore (26th September, 2017)
