Page 163 of 549 FirstFirst ... 63113153158159160161162163164165166167168173213263 ... LastLast
Results 2,431 to 2,445 of 8221
  1. #2431
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Yes! CAS cable sometimes doesn't work but mixing the order of connecting it makes it work...
  2. #2432
    How!!! And for ews?
    Enviado desde mi SM-G955F mediante Tapatalk
  3. #2433
    May 2017
    1."can't read password from w639,w203 and w202",some eis of them can,some can't,that it is.
    2.About manual,a good advice,thank you.taken it into consideration
    3.I think you are talking about Cas Plug?please check in 33page of the BMW manual
    4.BMW e46,use the HU92R?which option do cut the key?First measure the thickness of the blade,after cutting,measure the left thickness of the blade
    thank you for your trust,we try our best to
  4. The Following User Says Thank You to louis21 For This Useful Post:
    alex1881 (26th July, 2017)
  5. #2434
    Quote Originally Posted by louis21 View Post
    About 3 one... Checked manual, always do It before ask, I don't like touch the balls for nosense things...
    About manual, just contact me and I can help, also for making cables for test in bench too... Also, I can help to translate yo spanish if you want. Contact me.
  6. #2435
    May 2017
    about the cas plug,just remind to check.because I don't know if you know that or not,please ignore it.do you have log of that cas plug and car connection fail?
    Thank you!
  7. #2436
    yugo45's Avatar
    Quote Originally Posted by LauAlf View Post
    Files
    Eprom and immoblock
    Sorry for late replay, If you still dealing with this , can you post all key ID?
    I found problem , but need to see key ID to make sure they all match.
  8. The Following User Says Thank You to yugo45 For This Useful Post:
    LauAlf (21st July, 2017)
  9. #2437
    LauAlf's Avatar
    Quote Originally Posted by yugo45 View Post
    Thank you. I have recovered the file.
    Eprom line 0B90 old CS and learn keys.
    Hug.
    Enviado do meu SM-G935F atrav?s de Tapatalk
  10. The Following 3 Users Say Thank You to LauAlf For This Useful Post:
    amigokola (28th July, 2017), sniegavirs (21st July, 2017), yugo45 (21st July, 2017)
  11. #2438
    Apr 2016
    USA
    Ok this is not concerning any issue....just wanted to say love xhorse.
    I unlocked 8 Used locked BMW comfort access keys, paired them to the car everything works 100% very happy they added this feature.
  12. The Following 4 Users Say Thank You to BRMTDI For This Useful Post:
    lalaina74 (21st July, 2017), louis21 (22nd July, 2017), Maartinj (21st July, 2017), sniegavirs (21st July, 2017)
  13. #2439
    drugowaz's Avatar
    Mar 2015
    Lithuania
    need to solder with adapter to unlock CA keys for bmw?
  14. #2440
    Nov 2012
    Yes. But with vvdi prog or vvdi keytool. On keytool there are adapters without soldering.
    With vvdi 2 there is no link.
    So. Bad topic . Nothing to do with.
  15. The Following User Says Thank You to dorofteius For This Useful Post:
    yugo45 (22nd July, 2017)
  16. #2441
    Need help on this and I want to know if vvdi2 can do it.
    I have a Seat Leon PCR2.1 1.6tdi with ecu internal fault. I can read PIN CS and MAC from this. I have a spare ECU from scrapyard, but I can't read MAC CS and PIN because I only have the ECU?. Can I exchange ecu and write original PIN MAC and CS without having from spare ecu? If not, what I need to do this?
    thank you!!!!
  17. #2442
    May 2017
    no,if use vvdi2 to match,should know your spare ecu pin and cs
  18. #2443
    LauAlf's Avatar
    Quote Originally Posted by hipolitogt View Post
    thank you!!!!
    Read eprom new ecu, use cs and pin old cluster in you leon.
  19. #2444
    If I read eeprom can I find Mac CS and pin from It? Well, will try...
  20. #2445
    drugowaz's Avatar
    Mar 2015
    Lithuania
    porsche keys european has 433mhz frequency?
    cayenne,panamera etc.
