Page 172 of 548 FirstFirst ... 72122162167168169170171172173174175176177182222272 ... LastLast
Results 2,566 to 2,580 of 8219
  1. #2566
    how does copy 48 function work? Does it only work on passat B6/CC id48?
  2. #2567
    yugo45's Avatar
    Quote Originally Posted by lpf01 View Post
    from 2008 with EDC17.
    Tried to make key under passat key learning, and tried under read EDC17 in ECU menu too. Logs attached.
    Quote Originally Posted by louis21 View Post
    Got it,thank you!we are reading the logs.will reply you when get the conclusion
    Dear friend,please upload the datas(when read under the engine control unit,there is popup to remind you to save data).thank you!
    EDC17 read CS and MAC never worked with VVDI or VVDI2, in past updates they said it was fixed, but they never got fix .
    So if you have EDC17 you need to pull CCM out ,Only MED17 will work.
    EDC17 will read only Pin.
  3. The Following User Says Thank You to yugo45 For This Useful Post:
    keyantic (19th August, 2017)
  4. #2568
    Feb 2011
    Transponder programmer> Data Immobilizer> Asia, Kawasaki, Mitsubishi, 21175-0017 - 24c02 module not working, engine not running, with Tango is all ok.
    Please fix it
  5. #2569
    HeXeN's Avatar
    Mar 2015
    Hey, if more people interested in buy FEM activation, we could make a group buy to get better price straight from Samic? Any ideas? Im interested.
  6. The Following User Says Thank You to HeXeN For This Useful Post:
    sniegavirs (19th August, 2017)
  7. #2570
    drugowaz's Avatar
    Mar 2015
    Lithuania
    first off all need to get actual reviews off succes.
  8. #2571
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by HeXeN View Post
    Mate ...... SAMIC ... does not sell anything ....
  9. The Following User Says Thank You to PremierD For This Useful Post:
    yugo45 (19th August, 2017)
  10. #2572
    yugo45's Avatar
    Quote Originally Posted by dmp View Post
    This function is really not worth anything.
    You have to have 6 bytes CS form ECU and working key to be able to do it and it has to be pay with points every time you use it.
    If you have 6 bytes CS and working key , then you can adopt key in 1 min. Id48 is very cheap now less then 2 euros .
  11. The Following User Says Thank You to yugo45 For This Useful Post:
    dmp (20th August, 2017)
  12. #2573
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by yugo45 View Post
    this functions is : GET 12 byte UDS cluster CS , if you know 6 th CS
  13. #2574
    Ty, have been hopeful this can be a solution for spare keys on 2015+ id48 vw/audis....guess not!
  14. #2575
    May 2016
    hi all
    to samic:
    where to add authorisation function
  15. #2576
    drugowaz's Avatar
    Mar 2015
    Lithuania
    read messages. write to any xhorse dealer
  16. #2577
    Jun 2016
    Quote Originally Posted by SKYTON View Post
    hi all
    to samic:
    Dealer i.e xhorsetool.com
  17. #2578
    Quote Originally Posted by Maartinj View Post
    Cluster in passat b6/cc ??
  18. #2579
    May 2017
    Quote Originally Posted by profi View Post
    Please fix it
    Please upload the two files.the file used in VVDI to make the key and the file used in Tango,thank you!
  19. #2580
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by EMCE159 View Post
    Not have IMMO in cluster ,
    Caddy, Sharan, Touran etc . with NEC
