What is pricedure for audi a4 b8 09year all keys lost situation?
Same as for adding key, the only difference is that at some point you have to disconnect the BCM2 power and reconnect it. Just google "A4 8K all keys lost" and you will find a ton of videos about the matter, some are made with AVDI, but you should hve no problems understanding the procedure. There are some with VVDI2 aswell. Regards!
Lucky you you can read it on bench... Can you explain me how?
About the vcp driver. In 2011 version in ftdi driver properties you will have one checkbox that tells "load vcp driver" that makes load a COMPORT driver, you have to have it UNCHECKED. Try and post results...
And tell me how you succeed on read CAS on bench, if you have it, please explain, because my CAS plug doesn't work, and I checked all connections, maybe one is missing... But I don't think so...
Enviado desde mi SM-G955F mediante Tapatalk
I made my own cable. I'll upload photos of the pinouts, that way you can check your cable!
yugo45 (23rd October, 2017)
after update the installer to 4.7.6 and update the frimware it wokrs.it can see the cas over cas plug on bench!
dont forget restart cumputer
Why bother??? I've done it many times trough OBD with no problems even with crapy, clone of clone FVDI with no problems.
p1et (23rd October, 2017)
so those plugs need to be disconected for how long? and when need reconect them? need to disconect those 2 plugs or all? to read in bdm is no big problem module is not in very bad location
Mate, did you watch any video about the procedure? It is a really simple job, when the VVDI asks you to disconnect the BCM, you go to the right side of the trunk and disconnect the 2 connectors shown in video for 5 seconds and recconect them, after that you go on with making dealer key and progermm it to the car. Regards!!!
drugowaz (23rd October, 2017)
I have another issue! I programmed a A4 8K key to the car, it made the dealer key succesfully and added it to the car, the car starts with no problem, but the remote doesn't work. Same keys programmed with FVDI work fine. Anyone had this problem???
if you about this video
https://www.youtube.com/watch?v=VI0QgDUc984
i dont see how many plugs he disconects. and seems not connecting nothing back
