Page 217 of 548 FirstFirst ... 117167207212213214215216217218219220221222227267317 ... LastLast
Results 3,241 to 3,255 of 8219
  1. #3241
    LauAlf's Avatar
    But will always come out support for MQB?
  2. #3242
    Apr 2016
    USA
    Quote Originally Posted by Maartinj View Post
    What are you talking, do you recognize VW ?
    PQ35 kessy is since 2011 and you already did few Alex , stop making a mess
    simple add new key , or re-learn kessy key as you did many time
    But use PROXY key, not an ID48 , however ID48 working also as EMERGENCY KEY and you know that too
    Does not work, had customer vehicle again today, pre-code ID48 would not learn the vehicle, would not start the vehicle.
    Vehicle is 2017 VW
    Logged in, Cluster Goes Black, Read IMMO, Save IMMO, Make Dealer Key, Make Normal Key for Glass, Pre Codes ID48, Learn Key, Always fails, on older cars never had a issue, this one does not seem to work, when I do it in the way where it learns the keys 1 by 1, learns proxy never learns glass...ID48
    Tried by doing it VIA IMMO File, gives me an error... tried several times.
    If anyone has success with 2017 Similar car, please let me know...would love some input.
  3. #3243
    Maybe try emulator of id48. This way you don't have to write anything to cluster. Maybe writing new data is problem.
  4. #3244
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Possible add spare ?
    Audi a4 b7 2.0 diesel . 2005
    Key 8e0 837 220k
  5. #3245
    LauAlf's Avatar
    Quote Originally Posted by drugowaz View Post
    Key 8e0 837 220k
    Yes. Possible. Not possible swap "PowerClass" in VVDI2...
    Final add new Id48
    Enviado do meu SM-G935F através de Tapatalk
  6. #3246
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Sorry dont understand
    What is powe class.
    I need add new spare chip for start and remote from used key
  7. #3247
    Apr 2016
    USA
    Also tried to make dealer key, used same ID48 as one already made in the file, so the car has two keys that work, made dealer key "using already good working position info"
    Still no good, will write chip and lock, chip, will not start with that Glass Chip, will not learn it either.
    Also same tried to learn VIA file, also to try something different, always an error.
    Quote Originally Posted by EMCE159 View Post
    Maybe try emulator id48. This way you don't have to write anything to cluster. Maybe writing new data is a problem.
  8. #3248
    auto techniek's Avatar
    Mar 2017
    Hi M8
    can VVDI2 also do immo 3 key program passat 2002 or do I need some old devices ?
  9. #3249
    Nov 2012
    Work perfect in immo 3. I made passat b5 , golf 4 , seat toledo and others.
    You put blank transponder and it wil do the job in 2 minutes. Guided, so nothing to worry .
  10. The Following User Says Thank You to dorofteius For This Useful Post:
    auto techniek (20th November, 2017)
  11. #3250
    Mar 2017
    In this car is the id48 not precoded
    Procedure is: keylearn =====key learn ?
    Quote Originally Posted by dorofteius View Post
  12. #3251
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Not precoded. Regular keylearn.
  13. The Following User Says Thank You to drugowaz For This Useful Post:
  14. #3252
    Jan 2016
    You must add key to dump.
    In RB8 key learning doesnt work with VVDI2.
    What is powe class.
  15. #3253
    Nov 2015
    Did anyone ever try to work on NEC+24c64 2013+ TFT color display VW Passat dash with VVDI2? I just tryed to read immo data but it only reads some fields. It logs in succesfully, but reading only partial immo data. Changed km ok!
  16. #3254
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Passat have immo in CCM not dash
  17. The Following 5 Users Say Thank You to Faraday For This Useful Post:
    drugowaz (21st November, 2017), fytfh (21st November, 2017), sniegavirs (21st November, 2017), stefyhgs (21st November, 2017), yugo45 (21st November, 2017)
  18. #3255
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by amigokola View Post
    Ive already done RB8 with VVDI2.
    No problem m8.
