auto techniek (19th January, 2018), milehighlockdoc (14th December, 2018), yugo45 (19th January, 2018)
It is time for me to have a extra tool near vvdi2. One not extreme expensive.
auto techniek (19th January, 2018), Faraday (19th January, 2018), yugo45 (19th January, 2018)
VVDI2 latest software version V5.2.0 update
*** 2018-01-19
*** Require firmware V5.2.0
===== VAG V5.2.0 =====
1. Improvement MQB NEC35xx immobilizer/KM function, support following cars:
Audi A3/S3 2014+
Audi Q2
VW Golf7
VW Polo(MQB)
VW Tiguan II
VW Touran II
VW crafter 2017+
VW Passat B8 without virtual cockpit
Skoda Octavia III 2014.07+
Skoda Rapid 2015.06+
Skoda Kodiaq
Skoda Superb III
Seat Ibiza/Ateca/Toledo 2015.06+
Attention 1: This type only support cars with cluster Continental/VDO. JCI type and virtual cockpit was not include
Attention 2: Improvement for prepare dealer key: support original blank key and MQB key made by VVDI
Attention 3: MQB Immobilizer function require extra license. Customer who have copy 48 (96 bit) license will get MQB license for free
Attention 4: Improvement for key learn function
Attention 5: Bugfix for access some MQB instrument
2. Improvement for autodetct in IMMO4 system
3. Add spanish language
4. Bugfix
===== BMW V5.2.0 =====
1. Improvement for read ISN from MSx8x ECU, require VVDI2 database file verison V1.0.0
2. Improvement for load MEV17xx EEPROM dump
3. Support change second hand FEM/BDC ISN and make original key working
4. Add spanish language
5. Bugfix
===== Porsche V5.2.0 =====
1. Add spanish language
2. Bugfix
===== PSA V5.2.0 =====
2. Bugfix
===== Transponder Programmer V5.2.0 =====
1. Bugfix for update remote database
2. Bugfix for save points
3. Immobilizer data tool: bugfix for Fiat Ducato 93C56
5. Bugfix
===== J2534 V5.2.0 =====
2. Bugfix
===== Online Upate Tool V5.2.0 =====
2. Bugfix
===== Quick Start V5.2.0 =====
1. Bugfix
Notes: please keep using the latest software version, any problem post here or PM technical support.
amigokola (19th January, 2018), CaioW (19th January, 2018), damih (22nd January, 2018), Faraday (19th January, 2018), Maartinj (19th January, 2018), shanektm450 (22nd January, 2018), sniegavirs (19th January, 2018), weza247 (19th January, 2018)
really improved for update remote functions, but still have error E0-94 on end operation for generate remote
garage door remote always say need update, infinity loop, not work
So fujitsu learn only with pin?
7 bytes or 12?
Immo data can be extracted only from eeprom ecu or dash?
If 7 than possible write cs in chip and learn with pin?
Audi A3 8P has 7 Bytes always.
It's possible to get 6/7 bytes from ECU. If you get 6 from ECU you need to scan for 7th byte from working key.
Precoded keylearning is possible.
If you can read immo data from dash you get all 7 bytes
Ok got it......
Today i had a 2003 Golf 4 to program a new key and remote.
Programmed the transponder to start car ok, but had problems adapt the remote with VVDI2.
Tried adapt it manually in 46 - Central comfort module, when i put pin number it gives an error saying lost connection (see photo)
Then if i try going through the guided function to program the remote, it starts connecting to the module and the software crash and close down.
Tried for little while but could;t make any progress to got my SnapOn verdict out which manage no problems in like 1 minute and didn't even need to enter the pin.
WTF?!?;? you don't need pin to adapt remote!!!
46 comfort module
Adaptation
Channel 01 or 21
Input number of keys
Press test and save
Push for 2 or 3 secs any of the buttons, you will see emergency indicators in kombi and a horn and job done!!!
Enviado desde mi SM-G955F mediante Tapatalk
yugo45 (22nd January, 2018)
