Page 250 of 548 FirstFirst ... 150200240245246247248249250251252253254255260300350 ... LastLast
Results 3,736 to 3,750 of 8217
  1. #3736
    Oct 2016
    Scotland
    Quote Originally Posted by hipolitogt View Post
    WTF?!?;? you don't need pin to adapt remote!!!
    Ok, thanks for that.
    46 comfort module
    Adaptation
    Channel 01 or 21
    Input number of keys
    Press test and save
    Push for 2 or 3 secs any of the buttons, you will see emergency indicators in kombi and a horn and job done!!!
    Maybe so, however it didn't work.
    I could enter number of keys as 2 and press test button, but the save button remains blanked out so cannot proceed.
    Hence why i thought maybe this required the pin.
  2. #3737
    Quote Originally Posted by WRX 14 View Post
    Go to channel 00 and save. Clears out old remotes. I just do this automatically on a mk4 as adding them without clearing isn't 100% (and takes 2 seconds to clear them)
    Then channel 1 and enter the number of remotes you want to program.
    If still doesn't work use the one key in ign and one in door method
    Sent from my SM-G930W8 using Tapatalk
  3. The Following 2 Users Say Thank You to dmp For This Useful Post:
    royalkey (8th January, 2022), WRX 14 (22nd January, 2018)
  4. #3738
    Oct 2016
    Scotland
    Quote Originally Posted by dmp View Post
    OK, so do you think if the maximum number of remotes had been programmed into the car that the save button maybe remains blanked (because you can't add any more)?
  5. #3739
    Don't overthink it. You can only add remotes on this car using the door method so if you're doing it by obd just clear and add. Makes no difference if it only had one remote or four programmed already. For me works every time there isn't a ton of issues with the car itself.
  6. The Following User Says Thank You to dmp For This Useful Post:
  7. #3740
    wissamshaat's Avatar
    Oct 2017
    france
    46 comfort module
    Adaptation
    Channel 01 or 21
    Press test and save
    Enviado desde mi SM-G955F mediante Tapatalk
    he knows that dont need a pin to adapt remote . but its vvdi2 that asked for code and couldnt do the adaptations
    so he is asking somone to see logs and see whats the problem
    his tool couldnt erase the previous remotes neither adding another and he just want to know if its a soft bug or what
  8. The Following User Says Thank You to wissamshaat For This Useful Post:
  9. #3741
    Dec 2017
    vag key learning all key lost dash can anyone confirm im doing good
    1.reed eeprom by programmer 2.go service mode put or eeprom make serwice eeprom 3.start dash on the table 12V by obd write oryginal eeprom 4.reed immo data 5.make dealer key 6.add key?
  10. #3742
    immotool Corsa 0l72a bug unknown version running version 5.2
  11. #3743
    Mar 2017
    help me. I paid the authorization Xhorse VVDI2 Copy 48 Transponder (96 bit) to the dealer http://www.xhorsetool.com on January 19. And still haven't opened.
  12. #3744
    Oct 2016
    Scotland
    Quote Originally Posted by driver35 View Post
    Maybe because it has been the weekend, bear in mind the time difference in China too.
    I've dealt with them few times and never had any problems, have you tried to contact them and ask why it's not active?
    I would recommend that first before trying to get the company a bad reputation putting this here on the forum!
  13. The Following User Says Thank You to WRX 14 For This Useful Post:
    motorsport (24th January, 2018)
  14. #3745
    Mar 2017
    This morning I was told that everything was done, I can update and check, I updated and checked. Not active. After that I wrote again and attached a photo. No one answers me.
  15. #3746
    Oct 2016
    Scotland
    So after only a few hours of not getting a reply you reverted to putting it on the forum? Come on.... At least give them half a chance to sort out the issue.
    By the way, it can sometimes take several hours to update on the server before your device will update correctly
  16. The Following User Says Thank You to WRX 14 For This Useful Post:
    CaioW (22nd January, 2018)
  17. #3747
    auto techniek's Avatar
    Mar 2017
    It wil take a few days. They are not so quick as you think.
  18. #3748
    Mar 2017
    I paid on January 19 at 10:00 Moscow time. at 11 00 the dealer asked for a photo of open licenses. I sent it. the dealer wrote the moment and disappeared until Monday.
  19. #3749
    Maartinj's Avatar
    Nov 2010
    activations need 20min
    Update FW again, or send me s/n I can check what you have enable , what not
  20. #3750
    Oct 2015
    Soviet Union - USSR
    Michael are you still waiting function?
