AndyCZ (27th February, 2018), CarCity (22nd February, 2018), PremierD (22nd February, 2018), sniegavirs (24th February, 2018)
sucesfully we did CS, PIN and Power class (enought to adapt new cluster)
At the moment you need to know where to find that data in DUMP, edit manually and upload, but after you load file to VVDi you can see what you change .
only with emergency - yes
So you will do it push button function like read immo data write immo data and done on vvdi or need to edit manualy dump etc?
drugowaz (23rd February, 2018)
Great. If it will work like other immo 4 clusters read write .
but how you write that data in.
say i read immo data rb8 save .
than edit it say manualy,than load. when load it sais do you want load immo data etc. press yess,immo data loaded. when push write immo data i get message only vin will be written.
so how you write moded data back if vvdi oly let vin to write and not immo data?
Thats im asking now its clear
If youre developing more functions. Please fix passat b6 obd functions immo data read
Anybody can make key buy dump Citroen Xara 2004 st95160. VVDI2 no have this memmory type
Maartinj please write to Xhorse team to add Seat Exeo key learn (add to immo is enough for me).
Seed Key is different in this model then A4 B7... Someone here wrote that VVDI2 read this dash as A4 RB8 but no luck for me.
If they are working on RB8 now then it should be no problem....
Exeo is working with AVDI and SMOK.
Rgs.
It is like RB8 but not like Audi RB8.
I made km on RB8 audi with vvdi2 and it worked.
On Exeo RB8 it says login failed and that is it. But km work with Digiprog.
