Page 279 of 548 FirstFirst ... 179229269274275276277278279280281282283284289329379 ... LastLast
Results 4,171 to 4,185 of 8217
  1. #4171
    Jul 2015
    My Car
    Hi to everyone
    Seems that i have a big problem while trying to make key For F30
    FEM don't communicate anymore and weird sound when connect to VVDI2 and 12V on bench before even finish to program the FEM and be able
    to read most information in case we wanted to change it
    we backup the coding and read the chip 95128 when solder it again In wrong position the problem begin
    Now the chip is in right position but same problem
    we even change the chip but now way
    thank you for any help
  2. #4172
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Take new eeprom
  3. #4173
    In EEP
    Hi i have problem prepare transporder for Mercedes W168 PCF7931 after press write is unknow transporder. Pcf7931AS id73 read as sokymat 8E thanks for help
  4. #4174
    Jul 2015
    My Car
    Quote Originally Posted by drugowaz View Post
    Take new eeprom
    Already change the chip
  5. #4175
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This happened after service eeprom write?
  6. #4176
    Quote Originally Posted by adjee View Post
    Hi to everyone
    Try to measure voltage on eeprom pins. If you tried for long time maybe power rail for 5V is damaged.
    Worst case FEM MCU damaged.
  7. The Following User Says Thank You to exe123 For This Useful Post:
    yugo45 (23rd March, 2018)
  8. #4177
    May 2013
    Quote Originally Posted by vasa View Post
    This problem is for long on VVDI2 and not fixed.....
    Don't waste more transponders on VVDI with this old Mercedes Modules...
  9. #4178
    May 2013
    Quote Originally Posted by Samic View Post
    in fact VVDI2 also support to use this way, in this way it like you do the operation with working key.
    exactly use this method, it doesn't matter which device you used, when the proper PIN short circuit on cluster means you have working, then access to OBD device to communicate.
    but when you remove the cluster maybe ABS lost coding.
    So only need to join that point to GND anywhere and then power up cluster and it should read info as though in service mode?
    Not worried about loosing ABS coding as more important is getting the car to drive again after client lost all keys....
  10. #4179
    yugo45's Avatar
    if you read eeprom and flash not need downgrade flash you have dump for key....... .....
    This is what I am asking my self all this time, What is the purpose doing it OBD , if you have to take CAS and read eeprom /flash back up ?
    If you do that you can do key with key tag tool.
    And not just VVDI , all other tools are same way. So waste money for authorization like this , in other end you can do it with key tag tool.
  11. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    Brat (23rd March, 2018), jaelgti (23rd March, 2018)
  12. #4180
    yugo45's Avatar
    Quote Originally Posted by obeids View Post
    Pin 5 of eeprom 24c32/64 needs to be connect to ground. Every dash is different.
    https://www.youtube.com/watch?v=Fq6M...ature=youtu.be
    However I tried this with VVDI and did not work on one dash , I never try after that.
  13. The Following User Says Thank You to yugo45 For This Useful Post:
    kire106ka (29th March, 2018)
  14. #4181
    In EEP
    pcf7931AS identifing as 8E chip if i try make deaer key saz unknow transporder.....transpoder is new......
  15. #4182
    May 2013
    Quote Originally Posted by yugo45 View Post
    I have done quite a few of the CAS3+ downgrade on the car and then do the start cycle method WITHOUT EEPROM BACKUP. Never had a problem as long as power source of car and laptop were strong. It's always safer to have a backup, but not A MUST.
  16. #4183
    May 2013
    Hi there folks....
    Got a cluster of a VW AMAROK. Seems like somebody worked on it and left it in service mode. CLuster comes on but is in service mode. I can read / write eeprom and immo data without a key. When I read eeprom the Address 1430 = FFFFFF (for those who know what service mode address is).
    How can I get this cluster out of service mode since I don't have the original file. I tried contacting the person who apparently worked on it and he is not sending em the original dump.
    What's the solution of coding a key and getting this vehicle going?
    One more thing is that VVDI Identifies it as NEC + 24C32 whereas this cluster is actually 24C64. I opened it and checked it too......
  17. #4184
    ghostrider72's Avatar
    Jul 2012
    UK
    Upload any 24c64 immo block to it and restart it. Than act like all key lost.
    May work i think
  18. #4185
    Feb 2018
    I have the same problem.how to solve it? error e0-9c
