u.s (20th April, 2018)
VVDI2 bmw F30 , trying write data to FEM (FEM exchange) , response is error WUP failed , what does that means , and solutions of this ?
Thx
Hello friends. Anyone have tried to adapt used simos PCR2.1 with VVDI2? I know the CS, PIN and MAC from donor ECU.
Peugeot 508 2014 proxy key
pin read ok, but learning is stopped with unable to connect immobox or similar message
Nymike (20th April, 2018)
Hi there
The Transponder tool on the VVDI2 has another bug.
ASIA -> Hyundai -> Tiburon -> 2008 (29F400).
When you load the dump it says UNKNOWN VERSION. I have checked my file size is correct 512bytes. I read Flash again and still VVDI2 says same error.
I then took TM100 as last resort and loaded my same flash file there and it recognised the file and I made a 7936 transponder and wrote new dump and the car started.
Please fix this bug in Hyundai Tiburon 2008. If you want I can send the original dump and dump which I made.
@Rola1971
Not very smart job backup old fem , load backup and write to new one , and in my case it gives fault , will try to update FEM , and write backup to upated , main thing that chinease dont bother answer to questions (or even write manual about FEM) .
Did anyone else pay $250 for ID48 activation and did not get the 1500 tokens??
