Page 319 of 548 FirstFirst ... 219269309314315316317318319320321322323324329369419 ... LastLast
Results 4,771 to 4,785 of 8219
  1. #4771
    doctore's Avatar
    Nov 2015
    Colorado Denver
    My hair fell out
    And my 10 minute job is tourned out to a middle age spanish autodafé[/QUOTE]
    read cas with programmer eprom flash and pictures from cas unit
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  2. #4772
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by jodge View Post
    small story
    E91 2005 CAS3 (0L01Y) add simple key, not keyless system
    everything as usual
    connect
    read key info
    remove key..and what a surprise security bypass failed or similar
    ESL syncro gone, DME syncro gone, EWS tampered in the DME, MCU failed or similar in the CAS.
    My hair fell out
    Making backup on table before is huge job i understand... If you dont have any other e90 cas backup to use for this error repair then i don't understand why are you even doing a job like this!?
  3. #4773
    doctore's Avatar
    Nov 2015
    Colorado Denver
    we all bay tools for quick job on obd
    Sh-t always happens, what to do when we do such a job
  4. The Following 2 Users Say Thank You to doctore For This Useful Post:
    jodge (16th August, 2018), p1et (16th August, 2018)
  5. #4774
    jodge's Avatar
    Mar 2017
    easy...
    it's working i made it. It's just a story.
    Sorry for the misunderstanding
  6. #4775
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This is a bug after new update.
    Its not only you had this situation. Exacly 100% same error and same way bricked the car.
    If you have log file of that programming. Upload it. They must fix it.
  7. #4776
    Feb 2011
    easy...
    please share your experience, how to solve the problem?
    thnks
  8. #4777
    Maartinj's Avatar
    Nov 2010
    small story
    everything as usual
    connect
    read key info
    My hair fell out
    try to synchronize CAS and ELV , also CAS and ELV, car will ok
    usually this problem happend when car is low battery..
  9. #4778
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Martin this not work on this bug. It sais sync ok but car not start even when sync minimum 10 times. It thows errors in cas that cas failure mcu etc. Earlier version sync elv was enought ,this time no. It not help. Vvdi not sync cas ecu never. Need use other tools.
  10. The Following 3 Users Say Thank You to drugowaz For This Useful Post:
    p1et (17th August, 2018), RG550 (22nd August, 2018), yugo45 (17th August, 2018)
  11. #4779
    castin's Avatar
    Oct 2015
    Simply tool for syn elv, dme?
  12. #4780
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    Hi guys, im having a problem, someone bricked an MED17.5 ECU from a VW Golf Mk6 (5K chassis) GTi using Kess. Now the ECU came into my workshop but I cannot read it with VVDI...
    ERRORS:
    Device Error, please check whether the chip connection has a short circuit, if connection is right connect a 12V adapter and try again.
    Device error.
    All I want to do is write new flash on the ECU.
  13. #4781
    Oct 2015
    small story
    everything as usual
    connect
    read key info
    My hair fell out
    This happens alot for me with the early cas3 cars.
    I just drop the trim panel and plug straight into the CAS using the adapter without removing the cas from the car.
    The sync cas-dme never works for me using vvdi2. I use fvdi and it usually syncs within 3 attempts.
    Sent from my SM-G950F using Tapatalk
  14. The Following 2 Users Say Thank You to Bmkeys For This Useful Post:
    HeXeN (19th August, 2018), jodge (21st August, 2018)
  15. #4782
    jodge's Avatar
    Mar 2017
    for me the solution:
    CAS-EVL syncro (3-7 attempt)
    After the EVL was released
    i just checked the DTCs
    and CAS-DME syncro (first attempt)
    all done with vvdi2
    the old key was working and after that.... well cas3 is out and read it with prommer
    i don't want to do it thru obd again
  16. The Following 2 Users Say Thank You to jodge For This Useful Post:
    HeXeN (21st August, 2018), p1et (21st August, 2018)
  17. #4783
    Default VW Tourareg 2008 used KEESY Adaption
    I'm trying to adapt a used kessy to a Tourareg.
    VVDI asks me for power class, how to i get this?
    DJ
  18. #4784
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by djollie View Post
    DJ
    from ECU via Adaptation or from dump if you know where to look for that
  19. The Following User Says Thank You to Maartinj For This Useful Post:
    djollie (22nd August, 2018)
  20. #4785
    Quote Originally Posted by Maartinj View Post
    please find original ecu and kessy dumps...they appear to have different pin and cs....kessy is crypto?????
    i guess i should use vvdiprog to read kessy.
