Page 326 of 548 FirstFirst ... 226276316321322323324325326327328329330331336376426 ... LastLast
Results 4,876 to 4,890 of 8219
  1. #4876
    Apr 2016
    hi
    someone tried to add a key MQB audi a3 2014 ??
  2. #4877
    jodge's Avatar
    Mar 2017
    Transponder Tool
    Subaru Justy 2004
    ID4D-65 spare key added under Suzuki Alto 2002
    24C01
    eeprom memory must be updated.
  3. The Following User Says Thank You to jodge For This Useful Post:
    ghostrider72 (19th September, 2018)
  4. #4878
    Quote Originally Posted by kluczbum View Post
    hi
    I tried 2016 All ok
    Wysłane z iPhone za pomocą Tapatalk
  5. The Following 2 Users Say Thank You to EMCE159 For This Useful Post:
    amigokola (21st September, 2018), kluczbum (20th September, 2018)
  6. #4879
    RG550's Avatar
    Oct 2017
    Hi friends, I have an Audi A4 2005 year, RB8 2004+ cluster, is any chance to delete lost keys with vvdi2, or do all keys lost, or add key... I read in this thread that some things can do and some not, opinion is different, what is your experience with vvdi2 and RB8? Thanks
  7. #4880
    rob h's Avatar
    May 2011
    Make sure you back up cluster data.
    Then you are fine.
    These clusters can get stuck i learn mode 3-3 or something like that comes in the display.
    Some have had that, no problem.
    http://www.digital-kaos.co.uk/forums...8-error-L0-3-3
  8. The Following 3 Users Say Thank You to rob h For This Useful Post:
    ghostrider72 (20th September, 2018), milehighlockdoc (14th December, 2018), RG550 (21st September, 2018)
  9. #4881
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Quote Originally Posted by EMCE159 View Post
    I tried 2016 All ok
    just a quick one
    when in mdq say all goes tits up
    is there way to get back into system without the working key?
  10. #4882
    Jan 2016
    If you have immo data saved, even if you have wiped all working keys, you can still program back in with add key, then bottom option load immo data.
  11. The Following User Says Thank You to Cr4nky For This Useful Post:
    yugo45 (21st September, 2018)
  12. #4883
    Feb 2014
    Careful with those above 2015 - some are not MQB although the tools say they are. There are newer 48AES(or something similar, but definitely not ID88) which can only be done by the dealer no matter if you have working key or not.
  13. The Following 3 Users Say Thank You to autoTkey For This Useful Post:
    amigokola (22nd September, 2018), HeXeN (21st September, 2018), yugo45 (21st September, 2018)
  14. #4884
    has anyone tasted KM recalibration with VVDI2 on Passat B8 2015-2016 , normal dashboard?
    thank you
    Burko
  15. #4885
    castin's Avatar
    Oct 2015
    OK, so another question: BMW E61 2007 add key - VVDI2 read ok CAS eeprom by obd? E90, 91 tested, but e61 no:/.
  16. #4886
    lechus111's Avatar
    Jan 2014
    No equipment from any manufacturer, does not properly copy the eprom from the cas by obd, just add the key.
  17. The Following User Says Thank You to lechus111 For This Useful Post:
    doctore (23rd September, 2018)
  18. #4887
    castin's Avatar
    Oct 2015
    Quote Originally Posted by lechus111 View Post
    What do you mean? For add key need read and write cas eeprom.
  19. #4888
    Quote Originally Posted by castin View Post
    Just try don't be lazy...
    Enviado desde mi SM-G960F mediante Tapatalk
  20. #4889
    Apr 2016
    uk
    Hi people
    O have a problem with my vvdi2..
    After update 5.8.0 does not connect anymore to PC.
    If I try to 5.5.0 it can be seen by PC but I can't use it because sync with server.
    If I update it to 5.8.0 the PC does not see it.
    I used the update kit,it can see sn but if I try transponder or anything else the PC does not recognize it. Tried to uninstall all drivers and and install again. Tried on 2 laptops and on one of the laptops I don't have other ftdi installed..
    Any idea what can be wrong? Thanks
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
  21. #4890
    rob h's Avatar
    May 2011
    The update tool, should fix this. Press the device information option.
    You then often here the usb beeping , cause of the connection.
    I assume you run it as admin, and try with defender of antivirus off.
    You have manualy choosen the driver, in the device manager. (usb serial converter)
    So if you plug in the device, you see it poping up!
    Google : how to install driver vvdi2 ,might help
    Hi people
  22. The Following User Says Thank You to rob h For This Useful Post:
    comizelu (24th September, 2018)
