vsanyi (19th October, 2018)
BMW FEM key learning with ignition is not working
key is added but PCF is not locked
car is US 433Mhz, key i want to ad is US to
what can i do
Hi to all!
does someone make VVDI2 to work as passthru device?
i install tech2 odis techstream they dont work with VVDI2
They are not locked, but works. Car starts. tested.
Enviado desde mi SM-G960F mediante Tapatalk
and can you tell me what wold be my fault,
1 key renew choose the right eep 433 mhz F series and key is ori key and is US key
2 backup coding -> FEM open -> make service eep -> write service eep ->reassemble and connect to car -> connect charger to car->flash update->open FEM write ori eep and connect to car, restore coding-> read key inf -> select next free key (No 3 my situation) prepare key with ignition(put the remote to the key sign on the steering column) push prepare key-> 2 options
- 1 enter ISN
- 2 put working key o the key sign on the steering column
=> software feedback massage -> key make successfully
if read key info is pressed the key ID is displayed at No 3 but no remote function and key do not start engine.....
Please point out the mistake
car start once maybe, second time no more but even if it starts no remote function in my case
Problem is your key. Renew files not work with FEM as I know. Buy new key and everything should be fine.
p1et (22nd October, 2018)
So whats the solution Martin?
