Page 344 of 548 FirstFirst ... 244294334339340341342343344345346347348349354394444 ... LastLast
Results 5,146 to 5,160 of 8217
  1. #5146
  2. #5147
    Oct 2017
    VW transporter 2017. (My first MQB job)
    The working key number is 7E0837202BD
    I checked with VVDI2
    Ok, this is an MQB key (because 7E0837202BD available with ID48 and ID88 )
    I didn't have MQB key just a normal 7E0783202AD. The remote programming succes with this key.
    Key learn detected VDO NEC 2009+
    I selected key learn-> MQB platform and choose continental/VDO and Diag button.
    After I push the Diag button the VVDI automatically detect the VAG number: 7E0920970S, Version: H03 1104, Instrument type: 2014.06- NEC+24C64 and threw it to 4th immo system -> 2014.06- NEC+24C64
    Ok, read eeprom ->save file -> read immo data -> save file
    Make dealer key -> prepare OEM key -> choose the second working key ID (what was lost). succes (with VVDI ID48 transponder).
    I tried start the car. Start but after 1s stopped and got an error message: "no key" I tried start again but nothing happend just "no key". I started the car with the original key, works fine and then I can start with the new key until 1s.
    I understand that why not working: because I don't have MQB key it is fine but 4th system with MQB key? and the remote works fine with old 7E0783202AD remote (transporter/Amarok)?
    My question: Where can I buy the 7E0837202BD MQB key?
    If I get the MQB key then Can I programming it to the car?
    Sorry for the bad quality pictures
  3. The Following User Says Thank You to Sasika For This Useful Post:
    amigokola (13th November, 2018)
  4. #5148
    Dec 2017
    This is not mqb try on 24/64 after 2014
    Wysłane z iPhone za pomocą Tapatalk
  5. #5149
    jodge's Avatar
    Mar 2017
    if the working key TP recognised as MQB and the key available both UDS and MQB transponder then it looks like a mixed type...
  6. #5150
    ghostrider72's Avatar
    Jul 2012
    UK
    It wont work with normal ID48.
  7. #5151
    Oct 2017
    I understand. I wrote it i just tried something.
  8. #5152
    szengen's Avatar
    Jan 2017
    copying 48 fiat brava 2007 a mistake, it's the server if it does not go and, because it gets embarrassment,
    unknown return data 30200000000000000000000
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  9. #5153
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by szengen View Post
    try tomorrow, they still move server to new platform
    end of week should be ready
  10. The Following User Says Thank You to Maartinj For This Useful Post:
    szengen (10th November, 2018)
  11. #5154
    In EEP
    Quote Originally Posted by Sasika View Post
    you need after add key learning all keys via Pin option . It is bug .
    samic please add read and safe seed key from dashboard is very usefully option. if damage eep or if is error on learning new keys thanks
  12. #5155
    Jan 2016
    Audi A7 2016 USA Keyless. Making spare key no problem with VVDI2 ??????
  13. The Following User Says Thank You to amigokola For This Useful Post:
    yugo45 (14th November, 2018)
  14. #5156
    roth18's Avatar
    US
    Just got this tool. Trying to read CAS2 on the table 100Kbps no 120 ohm across. Result ---> "Connection Failed!"
    Trying with BMW Explorer (same setup). Result ---> OK.
    Is there something I need to do for VVD2 to connect, like port setings etc.?
    I try CAS3++ with VVDI2 and it connects OK at 1st but then looses connection and odes not connect anymore.
    Very weird.
    Thank You!
    Best Regards, Roth.
  15. The Following User Says Thank You to roth18 For This Useful Post:
    chcp (13th November, 2018)
  16. #5157
    Jan 2016
    Until what year we can do spare key in BCM2 Audi cars ?? As I remember till 2015 ??
    Newest car that I did was 09.2014 SW 0650 (date on BCM2).
    Quote Originally Posted by amigokola View Post
  17. #5158
    Jan 2016
    https://auto-keys.eu/index.php?route...ch=7E0837202BD
  18. The Following User Says Thank You to amigokola For This Useful Post:
    Sasika (14th November, 2018)
  19. #5159
    Jul 2012
    UK
    Lol. Nearly dealer price on that one
  20. #5160
    yugo45's Avatar
    Normally till 2015 , but I have heard this is mostly A4 , I head some A6,A7,A8 can be done even 2016 models.
    I guess only one way to find out to try to read it .
  21. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    amigokola (14th November, 2018), phuckyall (15th November, 2018)
