Page 103 of 549 FirstFirst ... 353939899100101102103104105106107108113153203 ... LastLast
Results 1,531 to 1,545 of 8222
  1. #1531
    yugo45's Avatar
    Quote Originally Posted by Faraday View Post
    I have ibiza 2014 witm MM dash 9s12 I can read immo data, prepare dealer key but I can not add key (by dump or obd) Do you know how to solve this problem? I did golf6 no problem but Ibiza doesn't work.
    Post eeprom file, and key ID for all keys.
  2. The Following User Says Thank You to yugo45 For This Useful Post:
    doctore (1st February, 2017)
  3. #1532
    Quote Originally Posted by qwojtus View Post
    Downgrade CAS 3 9395657. Process success but key did not work anymore. I did few times IstaP repair no success. I had the backup so no problem. Please fix it.
    You do backups everytime you make downgrade with VVDI ?
    To do backups you have to solder programmer (p.ex: xprog) wires directly to CAS board or there is other way?
    I do many times downgrade on CAS with VVDI2, and for now without any problem... but i dont like to do it... it is risky...
    Thanks!
  4. #1533
    CaioW's Avatar
    Oct 2015
    Everywhere
    Quote Originally Posted by ypt View Post
    Thanks!
    Yes this is what you need to do to make a CAS backup.
    Its kinda risky, but with an older version of VVDI2 for BMW (BMW MULTI TOOL) ive made alot of CAS downgrade and ever had problem.
    So until now with VVDI2 no problem to.
    And after the downgrade you add the key and the car dont start, try to sync ELV-CAS if nothing happen
    Clear DTC and Sync DME-CAS
  5. #1534
    Jan 2016
    So what was your problem in the end ??
    Quote Originally Posted by Nassreddine84 View Post
    Just for feed back mates i started the car and thanks for ur efforts guys sure no one born a master we all need to work hard to learn more and more and no pain no gain good luck
  6. The Following 2 Users Say Thank You to amigokola For This Useful Post:
    doctore (1st February, 2017), raptureready (1st February, 2017)
  7. #1535
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by yugo45 View Post
    key ID 2AD86822
    can you add to dump?
  8. #1536
    dyzio's Avatar
    Jan 2014
    Racek
    hi got question passthru work in vvdi2?
    Be yourself; everyone else is already taken.
  9. #1537
    Nov 2012
    No. It does not work.
  10. The Following User Says Thank You to dorofteius For This Useful Post:
    dyzio (2nd February, 2017)
  11. #1538
    yugo45's Avatar
    key ID 2AD86822
    Is this Only key that you have, or you have more then one key ?
    If is not only one key , then post all keys ID that you have.
  12. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    doctore (1st February, 2017), rola1971 (2nd February, 2017)
  13. #1539
    PierreTheron's Avatar
    Centurion,South Africa
    Ok we got passthrough device with vvdi 2 . Why i cannot use This J2534 device to connect to Toyota Opel Volvo GM software . I spent about three weeks on trying all this soft ....
    What a waste off time .. J2534 is suppossed to connect to any new type vehicle ,,,,.. So why they advertise it ???????????????????///
  14. #1540
    Dec 2015
    Quote Originally Posted by amigokola View Post
    Once vvdi2 ask u to insert and remove keys u need to switch off then switch on and keep holding until u hear the esl unlocking then u remove and insert the next one same procedure and at last u press on the msg prompted on vvdi means programming finished dont press ok before u program all keys
    NO ADVERTISING PLEASE
  15. The Following User Says Thank You to Nassreddine84 For This Useful Post:
    yugo45 (3rd February, 2017)
  16. #1541
    key ID 2AD86822
    Key added in position 4. You must lock and put cs into it CE 46 6C F0 02 6B 20 1D A0 81 DB FB
  17. The Following User Says Thank You to EMCE159 For This Useful Post:
    Faraday (3rd February, 2017)
  18. #1542
    [QUOTE=EMCE159;2947758]Key added in position 4. You must lock and put cs into it CE 46 6C F0 02 6B 20 1D A0 81 DB FB
    Sorry my friend I made mistake I put data from transponder that I'm working on now. In attachment your file corrected.
  19. The Following User Says Thank You to EMCE159 For This Useful Post:
    Faraday (16th February, 2017)
  20. #1543
    yep... instructions on avdi / fvdi are more clear.
  21. #1544
    Faraday's Avatar
    May 2012
    [QUOTE=EMCE159;2947802]
    Quote Originally Posted by EMCE159 View Post
    I can add key made by vvdi with smok but problem is I can add only 1key
  22. #1545
    I send corrected file, download and try. It hasn't been downloaded for now. Or just compare mine and your dump, and you'll see key id on 04B0, 04D0, 04F0 don't change anything in counter on 0410
  23. The Following User Says Thank You to EMCE159 For This Useful Post:
