Not always. I had a A3 2005, for Km job, and VVDI2 did not even knew what it was.
Just could not read any data from-it ... Digiprog, 1 minute , perfect.
But then I had another and no problem with it.
Thanks mates i will try, any hint which option ? Sorry new in vvdi2
Hi guys. How do you start to deal with a 2010 Audi A5 all keys lost with a damaged BCM2? The initial problem all keys lost. Someone tried to read the BCM2 and literally damaged the board.
Sent from my SM-G930F using Tapatalk
Hello lads. Looking for advice here. I not had a great deal of experience with vag stuff. However it's a brand I would like to learn. I get asked from time to time to swap a Speedo over and I've twice now been asked to code in pcr2.1 ecus. I have no tools to do either. So I am thinking about upgrading my abritus to full vag? Or vvdi2
P.s yes I have smok but not full for pcr2.1
Would you all post up your experience
Will vvdi2 do pcr2.1 ecu swaps and other modules?
Been asked to code in a srs module on a golf 7 it's saying component protection at the moment as it's from a Donar golf
Any and all advice appreaciated
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
norman1967 (13th November, 2017)
Remove CP with vvdi.possible?
Is there any VAG database to know which instrument type in which car is been installed?
must be etka
auto techniek (14th November, 2017)
ETKA will give you part number but not exact type. It will not show if A3 from 2006 is Micronas or Fujitsu.
So if not sure which type just make a guess and try.
So how add spare key? If possible read cs and pin. Than maybe write cs with tango and learn with vcds with pin?
