And how is that?
Yes you can on A6 4F, That is for ID48 what you saying.
If you have EZS eeprom from same car , then you can unlock key with VVDI2. If you do not have eeprom , then you can only remove antenna on top of the board and glue 8e glass chip, but remote will never work.
sniegavirs (28th November, 2017)
Like I said that is ONLY for ID48 .
For chip 8E , which AUDI A6 4F model has , even if you made key with VVDI only way to unlock it is if you have eeporm dump form evl/ezs where key was programed .
ONLY way to unlock A6 4F key is if you have evl/ezs dump , and YES used key can be unlocked on this model if eeprom dump is available form same car.
amigokola (29th November, 2017), lion0304 (30th November, 2017), sniegavirs (29th November, 2017)
yugo45 (29th November, 2017)
ID48 megamos is locked with random password (normally). Just if you create key with VVDI, AVDI it will write default password to Megamos before locking it. It can be unlocked later by VVDI or AVDI because it knows the password.
8E in Audi A6/Q7 key is locked with password which is part of eeprom (actually CS). That's why you need to have the eeprom to unlock it. Without eeprom dump VVDI/AVDI is not able to unlock it even if you have programmed it with it.
So for clearance.
1. When I have original ELV with matched key I can unlock it by ELV eeprom and adapt it to other car and key will work with remote function ??
2. It doesnt have to be key made by VVDI2 ??
PS: MED 9.5.1 Golf V can't read ECU flash or data (security access failure).
MED9.5.1 not VVDI2 foult even Kess didn't read it. Somebody have been there I suppose.
@ Samic, please, mercedes car all mask transponder dealer key function have bug, say unknown transponder, i really need this function, can you solve?
